Question about Electrolux Oxygen 3 Upright Vacuum Cleaner - EL5035 Vacuum
Height adjustment The height adjustment button on my upright is nonfunctional.  The Height is set closest to the floor and it makes it difficult to move on medium height carpet.
  • Wallydog May 26, 2008
    I did look under the sole plate and found the plastic piece that pushes the rod down, raising the wheels is stuck.  The spring is fine.  But this model is controlled electronically, so there was no way to fix this mechanically.  However I was able to attach a small piece of foam that raises the wheels so it is a little easier to push.  It'll hold until I get it to a shop.  Thanks...
  • cleaning gal Mar 05, 2009
    The height adjustment is not working, and since it is stuck on Bare Floor, the brush is not turning. I am having trouble finding a repair shop for this. Any suggestions?
  • 328 Answers
You'll have to turn the upright to its side to show the sole plate where the rolling brush is. Check where the front wheels are located and ensure there is no blockage obstructing the rotary dial. Sometimes the spring mechanisms can work themselves loose.
Inevitably you'll have to remove the sole plate and/or the rotary dial which may be screwed down. If it has cracked then you may have to seek a replacement.
Dont forget to rate this suggestion.
Posted on May 25, 2008
Height adjustment doesn't adjust work. Vacum Too difficult to push.
Are you Missing the Front Wheels under the Vacuum? This asswmbly can fall off
May 25, 2016 | Hoover Tempo Widepath Upright Vacuum -...
Height adjustment does not work
Hello! The vacuum does not move up and down when you change the height setting. When the handle is reclined is when the height of the nozzle will adjust. Hope this was helpful!
Jun 26, 2014 | Hoover Tempo Widepath Upright Vacuum -...
Height adjustment plate carpet
There is not a height adjustment plate on the vacuum. There is a bottom plate which is the part that glides across the floor. It has three plastic screws which you turn with a large screwdrive or a coin to remove the bottom plate.
Sep 17, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a Sharp vacuum EC-12TXT4 upright and I want to adjust the height for various carpets, how is this done? I have lost my owners manual and cannot find such manual on the internet. Could you please...
This model claims to have automatic adjustment. It has two foot pedals at the bottom which gauges the height of the carpet/floor. There's no other way to adjust the height.
Sep 04, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Vacuum height won't go on low carpet setting. Dial will go on medium and high, but not low.
Make sure you're not trying to adjust w/ handle in upright locked position because thewre is a cam which raises the vacuum head a little bit when handle is locked in upright position. If this is not the problem, turn vacuum upside down with handle in unlocked position and power cord not plugged in(for safety reasons obviously), unscrew and remove 3 screws that hold belt/beater brush assembly cover in place(2 are in corner near ends of beater brush and 1 is towards motor housing) tilt end of cover with 1 screw up and remove cover(there are 2 tabs at beater brush end of cover). Right above this is the height adjustment assembly with 2 rollers, raise up the assembly gently and using your finger or a bristle bottle brush,etc. make sure there is no debris caught between the height assembly and the hose(you will understand when you see it), if there is no debris you can now see the pattern on the bottom of the height adjustment knob and the lobe that rides on it, just check to make sure nothing is broken and/or missing, hope this helps!!
Dec 29, 2009 | Hoover Vacuums
How do i adjust the brush height on my dyson dc15 ball
The brushbar pivots, you can't manually set the height of it. It moves along with the contour of the carpet or floor that you are vacuuming.
Jun 26, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Can't adjust floor height on my Hoover Breathe Easy vac
on the bottom there is a smaller set of wheels in the middle check to make sure the spring is still in place
Apr 14, 2009 | Hoover Breathe Easy U5250-930 Bagged...
Electrolux Oxygen 3 Upright Vacuum Cleaner - EL5035 Vacuum Logo
431 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
