Question about Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
I have power to the unit but it won,t turn on any lights to select the cycle
  • rmaruy1946 Oct 02, 2010
    The solution was very hepful
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue seems to be its electronic control going bad and should be replaced; you can buy the parts from this link. However, before replacing the board check the door switch and also take it apart and blow air with the help of hair dryer on the board. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Tip
Whirlpool duet sport
Problem: you have stopped cycle before it is done and now the unit will not start. You can press power on and select cycle but when you hit start unit powers down.
Solution: power unit on, select a cycle hit start...before the unit powers down hit pause cancel and you turn the washer off before it can turn itself off. The unit should return back to normal. This usually solves your problem without having to replace the control board.
on Dec 22, 2009 | Washing Machines
Cycle won't turn on
Good Afternoon Marcia - Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the dishwasher. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
May 26, 2013 | Frigidaire 24 in. FDB1050RE Built-in...
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
Won't turn on
unit will only run on cancel cycle
Jan 29, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
Water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is jammed.fan should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Mar 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
Control locked light is on and washer won't turn on. Can press "Control On" and Cancel/Pause buttons at the same time to get the power on but won't start.
Looking at the manual of my Whirlpool front loader gives me the following advice...
CONTROL WON’T ACCEPT SELECTIONS
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the drain hose and drain
pump filter are clear of foreign objects.
3. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
4. Unplug washer or disconnect power.
5. Check harness connections.
6. Plug in washer or reconnect power.
7. Verify CCU operation by running a Diagnostic test or any
cycle
BTW: The full manual is at http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182208.pdf
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
First the f4 light flashed and we turned it off and on again and put hot water down the pipe which seemed to clear it - then the water finally drained from the maching - then it kept repeating the last 15...
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer.
Re select cycle and select HOLD to START.
If the issue persists then the F11 error is a Serial Communication Error Between MCU and CCU - Disconnect power and unplug unit. Check wire harness connections to the motor, Motor Control Unit (MCU), and Central Control Unit (CCU). Check the drive system for any worm or failed components and reconnect power and plug unit in. Verify CCU is working by performing diagnostic test or any wash cycle. Check MCU by looking for operation of the drive motor and check drive motor for powered rotations. Also check the motor and wire harness. Replace defective part as required.
Oct 12, 2009 | Washing Machines
Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher Logo
137 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
