Question about Maytag MDE2400A Electric Dryer
My Maytag electric dryer #PYE3300AYW, will not start and the light does not come on. I can hear the timer going, but nothing else will work. I have checked the continuity of the door switch and the hi-limit thermostat. What should I do next? Thanks. John
  • 3 more comments
  • itsgood483 Sep 30, 2010
    The door switch and the hi-limit thermo both have continuity. How do I check if the thermo fuse is good or blown?
    Thanks, John
    Did you get my question about how to test the continuity on the thermal fuse? I have not heard back.
    Thanks, John
  • itsgood483 Oct 01, 2010
    Maytag electric dryer #pye3300ayw will not turn on and the light will not light. I have continuity to the door switch and the hi-temp thermo. How do I get to the thermal fuse? I am not sure where it is and so far have not been able to remove the heat shield in the dryer tub. There is no access door in the back of the dryer that I can find. Please advise. Thanks, John
    Jahn27,
    Thanks for the info. I agree that it is the thermal, but cannot find it. The hi-limit thermo is on top of the heater coil and is easy to reach. There is very little access to the back of the dryer. Please tell me how to access it.
    Thanks, John
  • itsgood483 Oct 02, 2010
    Hit the nail on the head! Followed the instructions and everything works. Thanks,
    President:
  • 1,554 Answers
The problem is definitely the thermal being blown open. The neutral line for the motor is routed to the thermal fuse before the door switch. The motor cannot therefore run and the heater will not turn on if the thermal fuse is blown. The thermal fuse is located on the heater housing. Test the continuity in the same way the door switch and the thermostat are tested. You can also bypass it by taping the wires together and insulating them properly. It is indeed blown open if the dryer works fine. It must be replaced together with the thermostat w ith it on the heater housing. Do not use the dryer with the thermal fuse bypassed due to fire hazards. Bypassing it is for troubleshooting purposes only.
Please make sure to accept this post if you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how unhelpful or non-informative it is. Accepting a solution will not stop you from communicating with the expert should you need further help regarding the problem stated herein.
Posted on Oct 01, 2010
  • Jahn27
    Jahn27 Oct 01, 2010
    The thermal fuse is located on the right hand side of the heater housing and is mounted on a bracket. There is a 1/4" hex-head screw that holds both the heating element bracket and the thermal fuse bracket. Remove the said screw and the thermal fuse bracket can be lifted off.
    Figure 1: Removing the screw.
    Figure 2: The screw and the thermal fuse.
    Figure 3: The screw removed. The thermal fuse bracket has locating tabs at the bottom and at the middle, lift the bracket to clear the tabs and remove it.
  • 10,865 Answers
Hello John, If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on Sep 30, 2010
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
The dryer model # PYE3300AYW The dryer has power but will not turn on when the timer/start knob is pushed. You can hear the timer ticking, but nothing else happens. What are the possible causes for this?...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Maytag Dryers
My PYE3300AYW electric dryer stop heating.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;';';
Feb 22, 2011 | Maytag PYE2300AY Electric Dryer
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Mar 28, 2009 | Zanussi TD4112W Electric Dryer
Dryer won't start and smells like something is burning
I'm having the exact same problem verbatium! did you ever figure it out. I already replaced the motor and the belt, but it's still doing the same thing.
Feb 17, 2009 | Maytag PYE2300AY Electric Dryer
I have a Maytag Perform Electric Dryer Model #PYE3300AYW. It died in the middle of a cycle. All wiring has been checked, house breakers have been check, door switch has been checked. I replaced the...
If you have 240 volts going to the dryer the you will have a problem with the termal limiter, a set of contacts (normally closed) in the motor or your push button. Let go with the high limit since the pushbutton or the contacts are not in use when the motor is running.
Oct 22, 2008 | Maytag Dryers
Maytag performa pye3300ayw dryer
Check for burnt or loose wires at the junction where the power cord attaches to the dryer. Also check the door switch. When you open or close the door you should hear a click, that usually means the switch is ok. Then open the cabinet top and check for broken wires.Check unit with power off / cord unplugged!!! Safety First. Good luck. BpB
Aug 16, 2008 | Maytag PYE2300AY Electric Dryer
Maytag Dryer won't run
Maytag Atlantis Series MDE6400AYW --
Current is good, brand new power cord, drum light comes on --
When I turn the timer, I can hear it clicking, but nothing else works.
Aug 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer PYE3300AYW Continuously runs
jefo, it sounds to me like your timer is not advancing. Does it move at all or stay in place? In what you are saying it will stop when you turn it to off, I would think it could be the timer that is the problem. Part # 53-1810.
May 19, 2006 | Maytag PYE2300AY Electric Dryer
Maytag MDE2400A Electric Dryer Logo
771 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
