Question about Konica Minolta magicolor 2400 Laser Printer
"Paper jam at fusing unit section" but I have removed all the paper that was there.
    Problem Solver:
  • 4 Answers
Did you try to check the sensors and actuators? maybe the actuator sensor didn't return
Posted on Oct 01, 2010
HOW DO I CLEAR THE PAPER JAM 1? I opened all the doors and checked to see if any paper is stuck somewhere. There is nothing to keep it from starting again.
Did you check the fusing section from back door? When you open the rear door you can access the fusing unit (hotest place!!!). Sometimes the paper stacks below the stripping pawls of hot roller and you can't see it easy. Look harder! Pull out the whole paper tray and check below (printer bottom) for paper sheet. Lift upper cover and remove cartridge. You will see little green lever. Lift it up! Look for piece of paper around the little black pawl (paper sensor after registration roller). Restart printer!
Good luck
pifonski
Mar 03, 2011 | Samsung ML-2150 Laser Printer
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
Error code H5-01 how to fix on a sharp arm350u
That is a repeated uncleared jam in the paper transport. You may have a piece of paper wrapted in the fuser that you cant see, or one of the sensors on the transport between the paper feed and fuser are dirty.
You can try entering doagnostics, you press P * C * or # * C*, that will put the machine in diagnostics. Then press 14, then enter 1 then press enter. That will reset the machine, If the 14 routene doesnt work look for an uncleared jam or clean sensors.
Here is what it says.
H5 01 Content 5-time continuous POD1 not-reaching
jam detection
Detail 5-time continuous POD1 not-reaching
jam detection
Cause A fusing section jam is not properly
removed. (Jam paper remains.)
POD1 sensor trouble, or harness
disconnection
Improper installation of fusing unit
Check and
remedy
Check jam paper in the fusing section.
(winding, etc.)
Check POD1 sensor harness, and
check the fusing unit installation.
Use SIM14 to cancel the trouble
Aug 09, 2010 | Sharp AR-M350U Copier
MACHINE GOES OFF WHEN IT STARTS TO BOOT
Describe correctly whenever is the paper jam.If in the transfer section change the transfer/separator corona wire,and clean the sincron roller.If the paper is blocated in the exit parts,check the fuser unit parts and verify the exit actuator(located in the fuser unit).
Nov 05, 2009 | Minolta Office Equipment & Supplies
Call for service
Cause The fusing JAM is not completely
Fusing unit installation failure
Check and remedy:
Check for jam paper in the fusing section.
(paper winding, etc.)
Check fusing unit installation.
Check the jam sensors in the fuser.
Aug 24, 2009 | Sharp AR-M237 Copier
Remove a paper jam under the fuser unit on a canon image runner 5070
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
Aug 17, 2009 | Canon imageRUNNER 5000 Copier
PAPER JAM HP C4280
Hello sir; seems like your paper jamming in fusing unit, ok, her is the way, open the back cover, you may see have two blue handle on each side, lift them up then open the paper guide and remove the paper.
Apr 28, 2009 | HP LaserJet 4650 Color Printer Manual...
Canon imagerunner 5020i paper jams
Where exactly is the paper jamming in the unit? It would be helpful to know if it is at the paper feed units or within the imaging section of the unit or within the fusing and exit sections.
Many times paper feed problems can be caused by a faulty feed roller or roller bearing that is worn. Also have you tried other suppliers of paper for the unit? Are you using genuine Canon components (drum, toner, etc) or are you using 3rd party brands of materials?
It is quite possible that the unit has a gear with a broken tooth that is causing the noise. Without actually seeing the unit with my own eyes it is hard to say. When was the unit last serviced by a factory trained service tech?
Cheers,
Keith
Oct 23, 2008 | Canon imageRUNNER 5020i Copier
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Jammed papler
inspect your fusing unit carefully, do not use any sharp things, you can damage the fusing roller. see that the sensor is moving fine, that the separator are OK, not broken.
if thats not helping and you wont find anything, last thing is remove back and side covers, carefully remove TBU, unhook the connectors and remove two screws in fuser sides and remove fusing unit to inspect it a little closer.and find the problem.
Mar 21, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
