Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE oven jgbp30wea1ww broiler works oven won't light glow plug does not come on replaced still does not come on any suggestions
Krazytech
  • 725 Answers
SOURCE: Oven not lighting
Hi The gas valve will not open until the ignitor pulls enough amps around 3.2 . so from the infromation you wroke you may need a new ignitor..let me know what you can find out..
Posted on Sep 03, 2007
SOURCE: GE JGBP34 (XL44) oven won't light
Look at Lower Igniter
Check these two Sites here:
http://www.fixya.com/support/t141325-ge_xl44_range
and
http://www.fixya.com/support/t130970-ge_xl44_gas_oven
I just got this same problem today. Will do the same thing as these guys said in the morning. Good Luck.
Love these fix-it sites.
Posted on Jan 10, 2009
onthejob5130
  • 640 Answers
SOURCE: magic chef oven igniter will not glow.
the gas vavle..check for contiunity..just follow oven ignitor wire down ..onthejob
Posted on Jan 19, 2009
  • 126 Answers
SOURCE: Oven wont heat up.
after ignitor glows burners should fire within 30-60 seconds .if not your ignitors are weak (drawing less than 3.5 amps) and should be replaced Hope this helps ,please rate my solution :)
Posted on Jun 26, 2009
jsrock516
  • 5911 Answers
SOURCE: GE XL44 stove, broiler work fine. Oven won't light.
If this is a GAS range, the majority of the cases this problem is attributed to a bad igniter on the bake manifold. Each oven manifold (one for bake, one for broil) has its own igniter. They are both fed from the same gas source, though. So, if the broiler works, more than likely you simply need to replace the bake igniter. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake igniter tends to wear out faster, due to the frequency of use.
You can purchase replacements on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Just use you model number as your search criteria.
This is a simple repair that anyone can do on their without the need of a service call. Just follow the steps provided. If you have any questions, please let me know. I hope this helps you.
Posted on Jul 30, 2009
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
My GE JGBP32GEL Gas oven will not light. Electric pilot does not glow. Broiler work fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 07, 2010 | GE Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Oven glow plug on but oven wont light , dosnt get hot , top burners work fine. broiler also dosnt work . oven about 13 yrs old
if ignitor glows and the burner does not fire within 30-60 seconds it is weak (not drawing 3.5 amps or higher) and should be replaced. Hope this helps,please rate my solution
Jun 26, 2009 | GE JGRP17 Gas Single Oven
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
GE gas oven won't heat
did you do it your self or did you have some one else do it for you? I ask the question because the electricity most be unplug before you do it, If any of those wires made contact or spark. Now the safety valve it's also bad, you can test that by putting a tester for the 2 wires that connets to the ignitor to see if you are getting any power when thermostat is on. if there is power replace ignitor, if not getting power replace safety valve. Or maybe your clock is set on automatic, Set it on manual.
Nov 20, 2008 | GE JGBP28 Gas Kitchen Range
Oven won't light
Probably a bad oven igniter. Remove oven floor then remove flame spreader. Turn oven on and see if igniter glows. If it does and still doesn't light gas, it's probably weak. Replace the igniter!
If it doesn't glow, remove and take to your parts store. They should ne able to check it to see if it's opened up.. If so replace it!
Nov 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Aug 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
96 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
