Question about SanDisk Sansa e250 MP3 Player
My mp3 will not come on
When it is charging it works but when it is not it wont come on
  • 8,596 Answers
Try the volume + method below - if it fails, you may need to get a replacement:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
My trio mp3 player won't charge. i plug it in, and do everything it tells me to. it just wont charge.. what do i do?
When you plug the mp3 player in, look at the battery meter. If its not "loading" its not charging. If it is "loading" its charging. Well it worked for me. Hope it works for you. :)
Jan 08, 2010 | Digital Audio TRIO MP3 Player
My RCA Opal MP3 wont show up on my computer and it wont charge
This is battery problem, since it work with your computer directly, you no the computer power supply charge it directly so all you need do now is to get another battery and make sure you charge the new battery for some time before you power on.
Compliments and best of luck
Dec 25, 2009 | RCA OPAL M4001 MP3 Player
My mp3 go gear wont charge, i've tried to charge it on the ubs port and i've tried to synx it again and nothing is charging it
try getting an old usb phone charger and using that if that wont work then your battery may be dead and its time for a new one
Sep 20, 2009 | Philips PSS110/17 MP3 Player
My konaki mp4 player wont charge
maybe your mp4 player is switching off... try to turn on...
Jun 01, 2009 | Konaki MP4-NS MP3 Player
Will not turn on. this mp3 player has been on the charger all day
it may happen that the battery itself is brocken!!because it is over charged you said that its been charged all day...that might be the problem because if its over charged then theres a possibility that it wont be turned on or wont work..try changing the battery and try to turn it on..
May 18, 2009 | Haier ibiza Rhapsody Digital Media Player
It wont turn on!
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
Feb 04, 2009 | SanDisk Sansa Clip MP3 Player
My rca m4208 mp3 player wont turn on
i juat keep it on the charger to charge and it works again
Jan 10, 2009 | RCA M4208 MP3 Player
Mine wont turn on
On the back of the the mp3 player is a reset switch.
Hold that down about 15 seconds.
If that does not work go to the RCA website.
Download the latest firmware.
Plug mp3 player into pc.
Install the new firmware.
Keep it plug to computer for about 1 hour to charge the battery alittle.
Dec 27, 2008 | RCA M4204 MP3 Player
Wont turn on
yeahh peanut your going to want to submerge the device in lukewarm water for 3-4 seconds, then urinate on it. then it should work!
Aug 29, 2007 | Samsung YP-U2X Digital Media Player
SanDisk Sansa e250 MP3 Player Logo
14 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
