Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
ray smith Posted on May 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you remove the plastic end fitted to the flexible hose
My flexi hose has split about one inch from the plastic end fitting that slides along the metal tube. it must be possible to remove from the flexi, cut off a couple of inches of flexi and refit the plastic end.
  • 1 more comment
  • Anonymous Mar 14, 2014
    how to remove end fittings on canister vac hose
  • Anonymous Mar 21, 2014
    My hose had broken and the plastic end is stuck fast up the wand. How can I remove the plastic hose end so I can replace the hose
  • Anonymous Mar 25, 2014
    Split hose
Ryan S
Level 2:
  • Expert 328 Answers
  • Posted on May 25, 2008
Ryan S
Expert
Level 2:
Answers
328
Questions
Helped
199185
Points
778
Not necessarily. Some Dyson models have an all inclusive flexi hose which attaches to the handle spine. Check EBay for replacement flexi hoses - UK has many sellers - or handles which have the metal pole and the flexi tube attached.
Alternatively take off the flexi hose from the bottom rear of the Dyson - it can come out via a press in lock release but it may take some time to do this. Once that is done the flexi hose should come down freely from the metal tube. If it doesnt then you may need to consider both replacements.
Dont forget to rate, thanks.
I pulled the wand out of my dyson 25 handle and know it will not go down into the main part of the wand, help
has a clip inside the flexi hose, the hose must be fitted onto the wand before it will slide down
How do I remove hose from end that goes into vacuum cleaner?
if it is a convulated hose then it is screwed in to the fitting as if it is a left hand thread
the end section in the fitting is normally glued in to the fitting as well, so you will have to use a small flat bladed screw driver and pass it along side of the hose to break the glue
whenyou have the hose out cut off the bad bit or fit the new hose in after you put a small bit of contact cement in the thread of the fitting
How do I take the piece off vacuum so it can be used as a handheld
Lift red tab at top of handle then pull the entire handle upwards, this then gives you a solid tube about 80 cm long and a long flexi hose connected to the lower end. If you don't want to use the tube part there is a button at he fexi end that you press in. The different attachments can then be fitted either to the handle / tube or the flexi hose
Sep 28, 2015 • Dyson DC28
How to repair the lower intake flexible hose on the Hoover Agility
hoses are screwed into the end bits by turning in the do up direction
original equipment hoses are normally glued into the end piece but with a bit of determination and a flat bladed screw driver, the glue can be broken and the end removed
fit the good section of the hose into the end and screw it in using an un do direction
if it is the plastic fitting itself that is broken then weld the broken section back together
Basically use a soldering iron and heat the sections until the plastic melts back together
There are u tube pages that show how easy it is to do as they heat weld all sorts of plastic and tips on how to improve the strength of the repair. go google and type in how to weld plastic.
Take hose off to clean
Pull out handle as usual.
Release hose from wand and handle by pressing the pair of release clips on the handle just above where the hose enters. I have to press these clips quite hard and pull quite a bit to get the hose to come free. All the above is as you would normally use the hose.
Lay hose down to rear of machine. Just between the bottom of the hose and the machine body is a small plastic tab: pull this a little away from the machine body.
Slide bottom end of hose upwards and out of the machine.
The hose can be dismantled from the plastic fittings at each end but has not been designed for the user to do so: the hose and fittings are bought as an assembly (not expensive at about GBP15).
Only suction from hose
What again for the third time? Already answered this but if it helps:
If you have taken the bottom end of the machine apart, you might not have reassembled it correctly so that the path to the floor (base) plate is obstructed when the vacuum cleaner body is laid back, otherwise:
You have either a blockage in the section of the cleaner in the vicinity of the short flexible hose and the floor (base) plate or the the short flexible hose has become detached at one or both ends.
1. Stand the machine upright with the beater bar in the "off " position. Machine switched off but plugged into the mains outlet.
2. Lay machine on its left hand side. You will see the short flexible hose uppermost. Check that it is attached at both tends and has not split or cracked. Check for obvious visible obstruction inside.
3. Remove the floor (base) plate by releasing the three plastic clips with a quarter turn anti-clockwise. Lift floor plate forwards and check no obstruction. Replace floor plate. Stand machine upright on floor.
4. Press two plastic clips to release the inspection cover, on bottom right hand side of machine (when standing behind it). Look into the hole: you will now be looking down into the U-bend that leads to the hose. Switch on the machine: full suction should be at the hole on the side of the machine (otherwise the hose would not have worked). Switch off.
5. Lean the handle and machine body backwards, as though you were going to use the machine on the floor. The hole to the hose now becomes covered and you will be able to see into the short flexible hose that leads to the floor plate. Check for obstruction. Replace inspection cover.
If there's no obstruction and the flexible hose is sound and attached securely then the machine will work - there's nothing else to check.
The hose as torn along the metal ring. How do I
Hi Jim,
SmartAlec from NelsonVacuums.com.au here.
It is possible to take the end off and re-attatch (but its very fiddly and a real pain). You need to simultaneously push in the small oval pins on the side of the hard plastic part and pull the hose out. Be aware that there is 2 tiny springs inside and if they dont go back in the hose will not lock on. Once you have hose out simply cut out the bad part and reinsert to the end.
If this is too hard or some small parts go missing you will need a new hose.
You can get a new hose from NelsonVacuums.com.au
Hose for G3 Kirby doesn't fit Sentria
Yes G3 and G4 had different gasket thus the suction blower connector connecting Kirby hose to the unit on later models is different. You do not need to replace entire hose but just the plastic part that connects to the vacuum. You can find it HERE. To remove old connector you may have to submerge the end of the hose into hot water (not to hot to touch) so the vinyl becomes soft and you can bend it in with finger bringing plastic end over the lip on the molded end of the hose.
Good Luck
2helpful
2answers
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
16helpful
2answers
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 • Vacuums
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
