Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Yardman self propelled walk behind Right wheel does not engage with drive, left only is functioning .
  • behrens71 Sep 30, 2010
    Yes Needed confirmation before taking it apart.
    President:
  • 1,509 Answers
There's a shaft going from one wheel to the other a gear on the end of the shaft heald from turning with a key ( can be broken) then the gear is running on a gear made on the inside of the wheel, ( gear can be striped or wheel can be striped or the wheel can be coming off and the gear does'nt tou=ch the wheel. remove the wheel that doesn't pull and you can see the problem. Go on the internet to MTD and with your model number and serial number you can see the parts diagram for your mower and pick out the parts that you need.
Posted on Sep 30, 2010
The self propel system slowly stopped working and now doesn't work at all, what could it be?
You didn't specify the make or model of your mower, but generically speaking for self-propelled walk-behind mowers, the drive belt or the front wheel gears can wear out after several years of use. The drive belt could also be loose or off the pulley. The belt and the front wheels can usually be replaced.
You can remove the drive pulley cover and see if the belt is off.
The other components that make up the drive system are the gearbox and the engagement cable. Sometimes the cable can get get out of adjustment or come loose.
Jul 23, 2015 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Yardman snowblower won't self-propel
Do not start to do this but put the blower in gear like you would run to drive its self and try to turn the wheels by hand and if they turn easily then you may have a shear pin that is broken or missing in the drive pulley.
Just a thought.
Dec 12, 2013 | Yardman Yard-Man 31AH65LG701 357cc Gas...
Husqvarna Model 5521BBC. variable speed, walk behind, self propelled. The mower start fine, goes into cutting gear, but when I try to use the "self-propel" feature, it does not engage. It's rear wheel...
yes it could sounds like the cable is out of adjustment remove cover to see if belt still mounted and how to engage selfpropepelld adjust cable accordanlly
Aug 23, 2013 | Husqvarna Garden
Lawnboy 10665 won't self-propel and impossible to push
If you have the smell of rubber burning the belt isn't gripping. Make sure that there isn't anything stopping the wheels turning like old grass or even a piece of twig. If their clear try adjusting the tension on the drive pully.
Jun 28, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
424 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
