Question about Samsung Heating & Cooling
My samsung Split AC has some red light blinking along with a green one and its giving a different sound when i turn it on and the air/cooling does not come. It stays numb and the light keeps blinking. I tried fixing it by taking out the main plug and connecting it again but of no use. How do i get my AC started?
  • 234 Answers
SOURCE: split ac not cooling
I would check the drain to see if it is stop up.Next check to see if the unit inside is freezing up.If it is check to see if fan is running and if fan is running the you proable have a freon leak. Low charge on freon will make it freeze up and the fan not running also.
Posted on Apr 07, 2009
SOURCE: SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
Posted on Oct 26, 2009
  • 25 Answers
SOURCE: Samsung split AC is not cooling
Most probable short of refrigerant. Would have to have atech put guages on it and check.
Posted on Mar 11, 2010
riwaan
SOURCE: i have split ac samsung,which has problem with no
my friend us hould check your aircon have proper gas and may be there is a problem in your compressor u should chech power current supply of air con its possible there is aircon have short gas problem so contect to your a.c technician for further action.
Posted on Apr 25, 2010
  • 40 Answers
SOURCE: my samsung split ac is
could have leaked out all its gas. if its an older unit it may be cheaper and easier to replace the whole unit. will make a buzz noise occasionaly from the outdoor unit. this is the compressor tring to pump the gas that is not there. check if the fan on the outdoor unit turns on.
Posted on Apr 04, 2011
Need to know how a mobile home split system is wired with just ac and 15 kW heat stripesqqq
you have to have 240 volts for power. 24 volts to operate cool and heat. thermostat feeds color code white to heat yellow to cool green to fan. think of the thermostat as a light switch. transformer in system feeds common to different controls & usually red to thermostat which is then switched to what it is set for.
May 13, 2014 | Goodman CLQ36AR49 Air Conditioner
Lg split system
my home outside ac unit isn't blowing out any air the coils are clean yet for some reason the freon leaks out from the base out to the pipe. what seems to be the problem amd how can I fix this 7_7_2013_2_24_50_pm.jpg
Jul 03, 2013 | Heating & Cooling
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
Split a.c.1.5.ton, yesterday night stopped. one red light and 2 green lights blinking. a.c.not working. power is coming. what to do ?
Somewhere on the cover or the circuit board there should be a chart that tells you what the different light combinations mean. Look around inside the unit and try to find the codes and you can also check the owners manual.
Sep 05, 2010 | Samsung Heating & Cooling
Sep 02, 2009 | Samsung Heating & Cooling
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
282 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
