Question about Polaroid PDC 5080 Digital Camera
When i try to take a picture my camera says SD protected
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Polaroid Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Sep 30, 2010
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
When taking a picture a message pops up that says "cannot be written to SD card"
Checks to make:-
1) Is there an SD card in your camera?
2) Is the SD card compatible with your camera?
3) Is the SD card write protected (Check notch top left hand corner of card)
4) Is the SD card full or nearly full?
5) Are you trying to write a file type (.raw) which is bigger than the capacity of the card or the remaining capacity on the card.
Nov 01, 2011 | GE X500 Digital Camera
My Canon EOS camera was working fine. Now that I want to take pictures it say card write protection. How can I fix the came so I can take pictures?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try another card.
May 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
"card protected"
If that doesn't work, try another card.
Mar 09, 2010 | Vivitar ViviCam 8025 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Protected card flashes on my screen and I can't take a picture
    Take out SD memory card. Move switch to opposite position (unlock). Try in camera.
    Mar 17, 2009 | Fuji FinePix S2000hd Digital Camera
    Cant take picture. polaroid a500 camera reads sd protected.
    It means the sd card cant be accessed unless you remove the protection . Connect sd to laptop and use software to remove the protection .
    Mar 13, 2009 | Polaroid A500 Digital Camera
    Micro sd card says write protect when inserted what does that mean
    Hi , means you connot delete the picture , the only remedy to erase the write protect to format the micro sd , for the next time dont click to write protect .
    Mar 03, 2008 | GE E1040 Digital Camera
    SD memory card problem
    Have you tried sliding the little switch on the card out of the "lock" position?
    Sep 08, 2005 | Pentax Optio S Digital Camera
    Polaroid PDC 5080 Digital Camera Logo
    27 people viewed this question
    Top Polaroid Cameras Experts
    Greg Cann
    Greg Cann
    Are you a Polaroid Camera Expert? Answer questions, earn points and help others
