Question about Frigidaire Washing Machines
Water is dripping into the washer tub while washer is off and empty. (top load washer)
    President:
  • 1,430 Answers
The water inlet valve will need to be replaced. They are inexpensive and easy to replace. Here is a link that should help water inlet valve replacement
Posted on Sep 30, 2010
Maytag washer leaking water into tub when idle
A intake water valve is leaking and will need replacing.
Dec 30, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have an MAV7600 Maytag washer the hot water fill valve drip after the cycle complates
if the washer keeps taking water and even when the washer is on the off position.
The problem could be a bad water valve.
Mar 15, 2012 | Maytag MAV7600 Top Load Washer
Tub fills with water when machine is off and empty
most probably bad water valve/solenoid.  have had them drip once every 10 seconds or so and even fill tub when off...
Jul 24, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Water dripping into the tub. Whirlpool top loading washer
You just need to replace the water vale.
The valve is not closing all the way when its off.
Sep 05, 2009 | Whirlpool Washing Machines
Water leaking from water output at top of washer
soundsas if you have a faulty, inlet water valve. your model is notshowing up on my part look ups, but definatly replace the valve( your water hoses are connected to it. in mean time make sure to turn off water inbetween loads
Dec 11, 2008 | Whirlpool GSC9455 Top Load Washer
Water Dripping
you need a new fill valve, even if you ulplug the washer does it still drip? If yes then you do need a new fill valve. Just turn water off at the wall so your machine don't overfill.
Oct 28, 2008 | Kenmore 24032\24036 Top Load Washer
Water dripping into tub
One of your water solenoid valves are either going bad or stuck open with a little sediment. Find out which is leaking by turning off one of the water lines to the washer. If after it is turned off it still leaks try turning the first water valve back on the turn the other water valve off. This will help you determine which solenoid valve is having the problem. Once identified it is easily replaced.
Jul 30, 2008 | Maytag Atlantis MAV8551 Top Load Washer
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
