Question about Casio EXILIM Card EX-S770 Digital Camera
The following is not a battery problem and the camera has not been dropped. It worked normally, I turned it off, and the next day when I turned it on, here's what happened -- and has happened consistently since then: I turn the camera on. The lens extends fully. I hear 4 distinct buzzing sounds from within the camera. The LCD flashes with an image for a split second. The lens retracts fully. I hear 3 beeps from within the camera. The camera shuts itself off. All this happens in not more than 2 seconds. I have removed and replaced the battery both before and after fully charging it. I have removed the SD card. None of this has changed anything. Is there some sort of reset button or combination of buttons that may help? I've tried everything I can think of, as well as the few ideas suggested by the 3 previous FixYa people. Any suggestions?
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Casio service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 30, 2010
3 Suggested Answers
advance
  • 107 Answers
SOURCE: turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
Posted on Jun 08, 2007
t00nz
  • 4738 Answers
SOURCE: Lense is extended but will not retract combined
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Jul 23, 2009
My Canon A430 Camera got a bit wet when I fell into a Dam this weekend. The camera did not at all touch the water, but a few drops of water did land on the camera. After drying the few drops off, the...
Apparently, Some water worked its way into the camera circuitry. You need to stop trying to get it to work...you're only making things worse. Remove the card and battery. Bury the camera in a bowl of dry rice for a few days to absorb any moisture.
Jun 30, 2010 | Canon PowerShot A430 Digital Camera
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera will not turn on
It sounds like maybe somebody dropped it and is regretting to inform you of it. Other than that it could just be faulty
Apr 09, 2009 | Disney Pix Micro Digital Camera
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
Jun 30, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera no longer turns on.
Try polishing the battery contacts in the cover try ditt in the bottom of compartment with a cotton bud -or time for next camera
May 09, 2007 | Samsung Digimax 370 Digital Camera
DSC-T7 Locked up "USB Mode Normal"
I am a user with the exact same problem as you desribed for my DSC-T7. My problem started when I splashed two drops of water need the battery door and then the camera would not power up. I removed battery and card for a day and camera worked fine for another day. The following day, I left my camera in my sun visor of my car for the day (>90 deg F outside) which I forgot that I put it there. The next day my camera did power up in the locked mode exactly as yours. I do not know if it was the water drops or the heat but it is doing exactly as you desribe. However, here is something that I have discovered while trying to get the camera to work: 1. I plugged the adapter into the side of the camera since I am concerned that the USB port is the issue. 2. I plugged the USB cable into my portable printer and powerer the printer up and then turned on the camera in all three modes to see if anything changed and it did not. 3. I have found if you turn off the printer with the USB cable still in the printer and the adapter, the camera then enters a mode that shows thw word "ACCESS" and then the camera works perfectly. All modes of the camera work fine. But as soon as you power up the printer or remove any of the cables or remove the adapter the camera reenters the locked mode. This is not a solution but an indicator that the USB port is possibly causing the problem but not sure why the printer being off causes the camera to work fine. In addition, have all of the cables hooked up and to the printer does not allow the camera to be used with any mobility but wanted to let you know what I have discovered and hopefully maybe this may lead to a potential solution. Steve
Mar 05, 2007 | Sony DSC-T7 Digital Camera
Won't turn on
No it is a switching issue and is not going to get better. Kodak technical support will tell you more be prepared though -if you have had this for some time then the next camera purchase looms I guess
Jan 02, 2007 | Kodak EasyShare V550 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
