Question about SanDisk Sansa e250 MP3 Player
Please help 'need music'
My computer recognizes my sansa m240 mp3 player and i can add music on it but when i disconnect it my lcd screen will not come on it only come on when its connected so tell me is this a real issue or is something that can b solved easily it will not come on but when i charge it on the computer it is working
  • 8,596 Answers
Try volume + method, but may require replacement if it truly is a hardware issue:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
How do I edit my sansa m240 without the appropriate software?
You can connect the Sansa m240 to your pc, and in my computer you shall see the player. You can add music by dragging the mp3 files to the music folder on the player. You should see your other music currently on the player, in those folders.
Jun 06, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240 not recognized
If you're going to own an mp3 player, you may want to learn mumbo jumbo.
Double-click My Computer
Double-click all the removable disk drives until you get a window with folders in it instead of an error message.
Double-click My Computer again.
Double click My Music or wherever in the world you keep the music files on your computer.
Drag the files from the My Music (or other) folder to the folder that says Music.
-Tha Mp3 Doctor
Oct 15, 2008 | SanDisk Sansa m240 MP3 Player
My m240 can't be recognized!
Please make sure that you have your device on MTP mode (auto detect)..Then the computer should be able to recognize it...To make sure its working correctly uninstall it and reinstall it back from the computer..and that should solve the problem..let me know what the outcome..
Please rate accordingly
Thank you
Computerrep
Mar 20, 2008 | SanDisk Sansa m240 MP3 Player
Adding music.
open up windows media player and select copy to disk or device then drag you r songs to the right side of the screen and then on the left select the bar and find sandisk sansa m240 and then click the copy button
Aug 02, 2007 | SanDisk Sansa m240 MP3 Player
Recognise my sansa
to old for vista to recognize
Apr 29, 2007 | SanDisk Sansa m240 MP3 Player
Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
Apr 24, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
