Question about Sharp Microwave Ovens
Will shut off in all modes after 59 seconds. will keep countdown time when shuts off, restart and will start and continue count down time for another 59 sec only. voltage good. unpluged repluged. makes no differance.
  • Sharp Master
  • 9,086 Answers
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here or here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
Mar 24, 2016 | Sharp R-1870 Convection/Microwave Oven
Microwave plate turner keeps spinning even with door closed and microwave turned off
My microwave is doing this as well; It's a frigidaire model #FGMV154CLFA.
After using the microwave part (it is also convection), the light stays on in the microwave and the turner keeps turning.
And I've only used the convection part of my microwave a couple times and I'm not sure if I was successful. While trying to cook something in convection mode, I pressed convection, then pressed the temp i wanted, then convection, then keyed in the time I wanted the item to cook. The microwave started and the timer started counting down but the countdown stopped with 8 minutes left? I left it alone to see what would happen and it never finished so I restarted the process again.
PS..I've never gotten an error code
Apr 23, 2011 | Microwave Ovens
My Sharp R-975 Microwave after settin the timer and starting only runs for 59 seconds and stops, I can press start again and it goes for another 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
See the attached sample drawing for a typical damper assembly.
I'm not sure this is a US model or if parts are still available, so look up Sharp in your country.
Mar 13, 2011 | Sharp Microwave Ovens
The microwave shuts off after 59 seconds. You can push the START button and it will start again but shut off after 59 seconds. The convection oven component does the same thing.
We have the applicable service manuals for these models and have uploaded them to our site here, here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Dec 16, 2010 | Sharp R-1874 Convection/Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
Sharp model R-1871 shuts off every 59 seconds
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 30, 2009 | Sharp R-1871 Convection Microwave Oven
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Microwave oven shuts off after one minute
See the attached sample photo for a typical damper assembly.
What is your model number? We may be able to point you to the full service manual too.
The best place to order parts for this brand is Tritronics. Or you can call them toll-free at 866-779-5835. Their Web site re-opens tomorrow.
William E. Miller
prototech@usa.net
Dec 30, 2008 | Sharp R-1874 Convection/Microwave Oven
R957 cooks for 59 seconds then stops ,resumes for 59 seconds if cook /start pressed all cooking modes affected kitchen timer works ok
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 31, 2008 | Microwave Ovens
Microwave Ovens Logo
78 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
