New Pfaff 2058 -- fresh out of the box, and we can't get the voltage switch to move to 120V from the 240V setting. The switch is at the bottom of the machine. Do you know how to slide the switch?
There is a small clear plastic piece blocking the switch that must be removed, then use a small flat screw driver to flip the switch, you can throw away the small piece, it is only needed for shipping.
good luck!
If you're lucky only the power board is toasted. If it's bad luck then you'll have to replace both the power board and the main logic board. The good news is both parts together retail for under $100 US, so you should be able to find them on Aliexpress for a lot less. The bad news is the powerboard is not robust; if you want to use the Brother in Nigeria's 240V electrical environment I'd recommend using a 240v-120v step down transformer connected to a 120v UPS / Line Conditioner. Brother doesn't recommend that any of their computerized (sewing) equipment be used in poor power conditions or with step down transformers, the power circuits aren't built to be that strong.
Somewhere on the machine, usually the bottom, there is a switch to change the voltage settings of the machine. Please check that and your users manual for clarification.
no, it will definately run fine in Australia.Electricity in South Africa is 230 Volts, alternating at 50 cycles per second which is the same as Australia. The voltage in Aus and SA will be somewhere between 220/240v most of the time.
