Question about ASUS VK246H 24 inch LCD Monitor
No screen picture (no service) i haqve try a
No screen picture (no service) i haqve try a differed monitor with no problems. purchase:date,28/05/2010 staples store # 86 toronto on canada still under warranty.
  • 10,594 Answers
As you said monitor is still under warranty so I would not recommend to do any thing with monitor as it void its warranty.
Just call Staples Store and ask them warranty cover and get it fixed or get replacement.
Please do not attempt to fix/ repair monitor by yourself, this will void/ invalid its warranty and store will refuse your claim.
Hope these info will help you.
Thanks.
Posted on Sep 30, 2010
I have a Windows 7 home premium computer using a 1280 720 screen resolution. This is the recommended settings and everything looks right, shapes aren't distorted and such. But i installed Service Pack...
try to auto adjust with your monitor if possible or try a different resolution to see what works better
beyond that you may wanna try to rollback your display adapter's driver
May 06, 2011 | Microsoft Windows 7 Home Premium 64BIT...
No picture no sound grey blue screen
it sounds like the expensive part (the lcd screen) is ok, its probably a fault with the video board inside the monitor, this could be replaced/fixed. There could also be a problem with the power board. if it is either of these, the monitor needs to be serviced by a professional. you could try plugging the monitor into a different computer, if this is the problem it means you need a new graphics card, or need to re-install the graphics drivers on the computer.
Apr 27, 2011 | Hannspree 28" Widescreen Flat-Panel LCD HD...
I have model 1975NW. When power is turned on, green light appears, then orange light. No picture is present.
The ORANGE light indicates "power-saving" mode -- when no "output" from a video-card is being detected, the screen will dim itself. Try a different monitor. Try a different video-card in your computer. Try your monitor on a different computer.
Feb 03, 2011 | Westinghouse 19" Widescreen Flat Panel LCD...
No picture on screen
Try connecting the CRT to a different (desktop or laptop) computer, to confirm that the CRT is still working.
Try connecting a different CRT (or LCD) monitor to your computer, to confirm that your computer is sending video-output.
If possible, try a different "data" cable between the computer and the CRT.
Jul 20, 2010 | HP Compaq FS7600 17" CRT Monitor
My screen only shows a picture for a few seconds
Try connecting a different monitor to your computer, to see if that monitor shows the same symptoms. If so, your computer, not your monitor, is the problem.
Try connecting your monitor to a different computer (desktop or laptop) to see if the problem "follows" the monitor.
Jul 17, 2010 | ViewSonic VX900 19" LCD Monitor
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Jul 18, 2009 | Dell Computers & Internet
LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
Problem with Interface board or panel.
Also maybe due to defective powersupply filters.
Samir
Dec 10, 2008 | LG Flatron L1710B 17" LCD Monitor
try your monitor to other computer or try other monitor to your computer to see where is the problem
Dec 09, 2008 | Computers & Internet
Display area extends beyond the area of the monitor
Hopefully there is a cable loose or something like that. Try reseating the cabling. I think it is a monitor problem but it wouldn't hurt to try the monitor on anouther computer. It sounds lke a heat problem in the monitor scanning circuitry. It may be repairable if the picture is still looking good. Youll need a schenmatic and some patience and a soldering iron or a reputable service tech.
Sep 20, 2008 | X2Gen MG19MY 19" LCD Monitor
Turn on the monitor the screen says "out of range" in a small window and turns off
Lower down resoluction and color quality to minimum on your pc, using 'display properties' in Windows. Connect the monitor back to pc with minimal settings. If it works is done.
If it still does not work there is a major problem with the monitor. In this case It should be opened and tested inside following schematics. In this case you may need to take the monitor to a service in your area.
regards
Mar 02, 2008 | Sceptre DCL9a
ASUS VK246H 24 inch LCD Monitor Logo
67 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
