Question about Samsung X05 Notebook
Network Authentication in Vista
I can't find the Wireless Authentication tab for me to enable the IEEE 802.1x in Windows Vista
  • Cha82680 May 26, 2008
    In windows XP I can find the authentication tab, but in Vista Home edition don't have it. I installed Linksys WRT54GS router but I can't connect to the internet. I click for the help and support of vista and showed that I need to enable 802.1x but I can't follow the steps because I can't find the authentication tab in the properties. I'm not also sure if the wireless in the router is already in enable.
    Scholar:
  • 187 Answers
Right click the network icon in the system tray, and click Properties, from there, click Authentication.
Posted on May 25, 2008
  • Steven Burn
    Steven Burn May 27, 2008
    To check if the wireless is enabled on the router, connect an ethernet cable between the computer and the router, and login to the router via it's web interface (usually 192.168.2.1 or 192.168.1.1 for Lynksys).
    With regards to the Authentication tab, are you logged into Vista as an administrator?
Windows was unable to find a certificate to log you on to the network OS is XP SP2 N614
Here's how to connect to your wireless router if you are getting this message:
First, click on the wireless icon in your taskbar and under Related Tasks, choose Change advanced settings.
Now click on the Wireless Networks tab and select the network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Click on the Authentication tab and now uncheck the Enable IEEE 802.1x authentication for this network box. If the box is checked, then that is why you were getting the "unable to find a certificate to log you on to the network" message because Windows is looking for one, but your wireless router is not setup for certificate security.
And that's it! Once unchecking the box and try to reconnect to the wireless network, everything should work fine.
Hope this helps!
Apr 06, 2011 | NetGear WGR614 Wireless Router
Tip
Windows problems connecting to WPS enabled routers
You may come across connection problems when routers have Wi-Fi Protected Setup (WPS) enabled and clients do not support it.
In Windows XP, Wireless Zero Configuration (WZC) may mistake a WPS enabled router for a WPA-Radius protected one and warn you that there is no certificate to connect to it:
To work around this problem, you can either disable 802.1x authentication on the client or disable WPS on the router's.
802.1x on the client can be disabled in the properties of the wireless network. On the Authentication tab, untick the 802.1x Authentication option. Make sure that the correct encryption type is selected on the Association tab and that the WPA Pre-Shared Key or the WEP key is entered.
On Windows Vista things may even be worse. When you try to connect to a WPS enabled network, Vista may prompt you for a user name, password and domain name as if PEAP authentication were used. When you manually create the network profile specifying WPA2-PSK, AES and the Pre-shared Key, Vista may refuse to connect stating that the network profile does not match the actual configuration. The only work-around in this case is to disable WPS on the router.
To disable WPS on the router, go to the Wi-Fi Protected Setup.
To learn how to disable WPS click here...
At the top of the page, just set WPS to disabled and apply changes. You may need to delete the profile for the network on the client card before it can connect to the router.
on May 05, 2010 | Computers & Internet
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
When trying to access my wireless network it tells me that it cant locate a certificate to log on to my wireless connection. What does that mean? I have two other children who received these netbooks and...
If u are using Win XP, try the folowing steps.
Click on the Wireless Networks tab and select your network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Once unchecked that box and try to reconnect to the wireless network.
If you are using Win 7 Starter, Try teh following steps.
Click on Start and go to Control panel>Network & Internet>Network & Sharing Center.
On the left side u will find Manage wireless networks. Click on it.
Now select your network in the list. Click on Properties.
Dec 25, 2010 | Acer Aspire One PC Notebook
Wireless will not stay connected.
Hello
If you have VISTA this is a very common problem. If you have XP or Win 7 you'll need to talk to ACER tech support about a replacement motherboard. Like I said if you have VISTA this is common. Microsoft was supposed to correct this problem with SP2, but I've still seen it.
Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, point to Connect To, click Show all connections, and then double-click your wireless network adapter.
  2. On the General tab, click Properties.
  3. Click the Wireless Networks tab.
  4. Under Preferred Networks, click your home network, and then click Properties.
  5. Click Data encryption (WEP enabled).
  6. Click the Association tab, and then click to clear the Network Authentication (Shared mode) check box and the The key is provided for me automatically check box, if they are selected.
  7. Click the Authentication tab, and then click to clear the Enable IEEE 802.1x authentication for this network check box, if it is selected.
  8. Click OK two times to accept the changes.
uparrow.gifBack to the top Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, and then click Control Panel.
  2. Click Network and Internet, click Network and Sharing Center, and then click Manage network connections.
  3. Right-click the network that you want to disable 802.1X authentication for, and then click Properties.
  4. Click the Security tab, and then, in the Security Type list, click No authentication (Open). Click OK.
http://support.microsoft.com/search/default.aspx?qid=449435&query=vista+drops+internet+connection&catalog=LCID%3D1033&mode=r
Mar 03, 2010 | Acer Aspire 7720 Notebook
Netgear wireless router wgr614v7 not transmitting a signal anymore. everything seems fine but it's not pumping out the signal.
Dude try the following steps it will help,else let me know the exact problem
  1. Click Start > Connect To > Show all connections, and then double-click your wireless network.
  2. Click General > Properties.
  4. Under Preferred Networks, click your home network and then click Properties.
  5. Click Authentication, then clear the Enable IEEE 802.1x authentication for this network check box. (If you cannot click the check box, then you are not using 802.1x authentication or wireless security.)
Dec 29, 2009 | NetGear WGR614 54Mbps Wireless Router...
While trying to connect a pc to the WRT54G2 wireless broadband router,windows gives me the following message: ''windows cannot find the certificate to log on to the linksys network'.what is the problem...
On Windows XP
>>right click wireless connection icon >>view available wireless network >>click on change advance settings inte left(SP2) orAdvance(SP1) >>on top click on tab wireless network >>clear preffered networks >>Click on ADD below preffered network box >>Put in the details for the titles mentioned below Association(Tab) >Network Name (SSID) : put in your wireless network name >Data Encryption should be check >Network Authentication(Shared mode) should be unchecked >The key is provideded for me automatically uncheck it >put the network key and confirm it Authentication(Tab) >check Enable IEEE 802.1x >now uncheck Authenticate as Computer when computer info is available >now uncheck Authenticate as as guest when user or Computer when computer info is unavailable >uncheck Enable IEEE 802.1x >>click OK now it will start working enjoy
Sep 29, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Attempt to go on wireless and get "need certificate" to continue. Any help for this?
Hi!
Here's the solution to your problem:
1. Go to Control Panel > Network Connections
2. Right-click on Wireless Network Connection > Properties
3. Click on Wireless Networks tab. Remove all the names under Preferred Networks box.
4. Click on Add button. Type the Name or SSID of your wireless network
5. If you have encryption enabled, uncheck the box at the bottom "The Key is Provided for Me Automatically".
6. Type in your wireless encryption key in the given boxes.
7. Now click on Authentication tab. Uncheck the box that has the "Enable IEEE Authentication".
8. Click Apply and OK all the way out. Restart your computer.
9. It should be able to connect wirelesly.
Jul 28, 2009 | Computers & Internet
Wireless network connection, Intel (r) pro/wireless 2200bg says not connected. How do I get it to say connected? I have disabled it and then enabled it and to my surprise it still says not connected- How...
Try these first:
Make sure that the wep password is correct.
change channels to 1-6-or 11.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Feb 18, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Wireless adapter disconnecting and reconnecting
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers.
You can find at setting under "Wireless Network Connection1.gif Properties" and then under "Authentication" tab of your network properties.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Are you using the VISTA adapter driver on the disconnecting computer?
Jan 13, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Samsung X05 Notebook Logo
60 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
