Question about Kenmore Ovens
Kenmore electric range model 790.95423302 oven element does not work (heat up)
aborcass
  • 2651 Answers
SOURCE: heating element in GE Range Oven
get the model number and order the exact repacement bake element
Posted on Mar 10, 2008
  • 161 Answers
SOURCE: Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Posted on Jul 15, 2008
  • 1462 Answers
SOURCE: Kenmore MODEL #790.95302104 electric range
suspect you have oven on automatic by mistake. get your book out and reset the clock
Posted on Sep 14, 2008
  • 86 Answers
SOURCE: Replaced heating element now oven wont work
Hi what make is your oven?
Posted on Feb 05, 2009
  • 127 Answers
SOURCE: kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Posted on Oct 25, 2009
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Kenmore electric range oven baking element does not go on eveything else works
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Jan 30, 2014 | Kenmore Ovens
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
Kenmore electric range with ceramic cooktop, model # 79046593500. None of the elements or the oven will heat up. The controls work, the red indicator light goes on, but no heat.
It sounds like your Frigidaire made kenmore may have a power supply issue, the power block that is located at the rear of the oven may be at fault. part number 5303935061. However the digital clock can also cause this problem, and should be diagnosed by a technician.
Mar 14, 2010 | Ovens
Kenmore electric range - oven temp low and takes forever to heat
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
I have a Sears Kenmore electric drop in range, model # 911.4552092. That's what it says underneath the cooktop. The cooktop works fine, but the stove does not work at all. It suddenly went out while it...
Hello. I can help you.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Since it is a Kenmore you can get the part at Sears.com. You can price the part there. I can assure you that a technician will charge you at least $125. to do that repair. If the range is old, you may wish to put that money toward a new stove.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore range stove model#79096011401
Make sure the wires are on the control switch. They may be burned off.
Oct 21, 2008 | Kenmore 47783 Electric Single Oven
Heating element in GE Range Oven
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Range 911.9324890
Replace recepticles for large elements. It is the part that the heating elements go into. And while you are at the appliance store, pickup a new bake element for your oven. Just unscrew element from oven wall and install new one.
Nov 16, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
122 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
