Question about Maytag Appliances Over-the-Range Microwave Oven
I have a Maytag OTR Microwave oven that doesn't work. After I close the door and set the time and start, I see the time countdown, but I don't see the microwave starting. I can get the microwave to start, if I keep pressing the top of the "control panel" above the display hard. The moment I let go, the microwave stops (but the countdown still continues). To debug further, I just unscrewed the control panel and got it slightly out, so that I can check the door switch and other connections, everything seems to look good. I am running out of ideas, so seeking help
  • Maytag Master
  • 9,047 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
See our file on door switches here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Oct 03, 2010
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Advantium 120 not working
see this causes and fix it. God bless you
If the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan.
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout, and the fan, replacing parts that don't pass the test.
Oct 15, 2012 | Maytag MMV1153A Microwave Oven
My microwave shows nothing on display and will not turn on
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 27, 2012 | Maytag Appliances Over-the-Range Microwave...
Bought a used Sharp OTR Microwave don't know how to set the time of day
Google the model number with manual to try to locate a free owner manual for the unit.
Aug 27, 2012 | Microwave Ovens
Otr starts as soon as you close the door before you select any option
One of the door switches is probably defective, replacement only option.
May 31, 2012 | GE JVM1850SMSS Microwave Oven
Bosch combination oven/microwave HMG 8220GB start button doesn't work
This is a door switch problem, one of the door switches has malfunctioned preventing the microwave oven from running.
May 14, 2012 | Bosch Microwave Ovens
When I set the timer and close the door, the door latches fine. When I push the start button the timer starts to countdown but the microwave doesn't start. If I push the door release in about 1/8 " ,...
If your model number is in the Sharp R-1500 series, then that's a problem with the bottom door switch or its mount.
See these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Jan 14, 2011 | Sharp R-1511 Microwave Oven
Whirlpool OTR microwave no oven 'fan'
FIRST ,,MICROWAVE OVENS ARE REALLY SAFTY MINDED AND THATS A GOOD THING....THERE ARE USUALLY THREE DOOR SWITHCES NEXT THE KEYBOARD--THE ONE ON TOP AND THE ONE ON BOTTOM ARE PRIMARY AND SECONDARY SWITCHES,,YOUR PROBLEM SOUNDS LIKE ONE OF THESE IS NOT MAKING CONNECTION..YOU MIGHT BE ABLE TO PRESS 'DOWN" WITH A LITTLE PRESSURE ON THE DOOR AFTER CLOSING TO SEE IF THE FAN WILL START,,,IF YOU NOTICE --THERE ARE 2 LATCHES(HOOKS) COMING OUT OF THE DOOR,,WHEN THE DOOR IS CLOSED,THOSE LATCHES ARE SPRING LOADED AND MAKE CONTACT ON THOSE SAFTY SWITCHES....THIS IS NOT A CUSTOMER REPAIR--MICRO'S ARE JUST TO DANGEROUS WHEN YOU TAKE THE COVER OFF--IF THIS DOES BRING THE FAN BACK ON--YOU GOT A BAD DOOR SWITCH AND SHOULD BE A REASONABLE REPAIR
THE OTHER SOLUTION STILL WOULD BE A CONNECTION PROBLEM ON THE KEYBOARD ITSELF-THE WIRES JUST PLUG ON THE CIRCUIT BOARD BEHIND THE KEYBOARD---STILL A EASY REPAIR--GOOD LUCK TUNICA
Oct 30, 2008 | Microwave Ovens
Maytag Appliances Over-the-Range Microwave Oven Logo
146 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
