Question about GE HVM1750SMSS Microwave Oven
My ge microwave just runs. It will not stop unless I unplug it.
  • GE Master
  • 9,047 Answers
First you should determine whether it's cooking when it should not be, in this case anytime it is plugged in and the door is closed or open.
Do that by putting a cup of water in a microwave-safe container into the unplugged microwave, shutting the door, then plugging it for about a minute.
Then unplug the oven and check to see if the water is warmer.
If so, you have a shorted secondary relay on your microwave''s control circuit board, and we regularly repair such control units for customers nationwide by mail for $39.95 with a one-year guarantee.
Do that test again by putting the water in, leaving the door open, and plugging the oven in for about 30 seconds or so. If you get any arcing or buzzing or flashing, unplug it.
If it is not cooking, then you need to test further.
If it just seems to be "running" with the door shut, but it is not cooking (as shown in the above tests) then note whether the oven lamp, internal cooling fan and turntable are running when the door is shut, but when you open the door, the turntable and colling fan go off.
This should mean you have a shorted main relay on the board. We can fix that, too.
Differing symptoms would indicate a bad door switch or door switch mount.
Our info file on door switches is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 03, 2010
How to replace door switch on advantium
Happened to my 2005 Advantium120 twice, both times after extended cooking/simmering on the cooktop (17" below). Solution was to leave unplugged for a good 48 hours (to dry out?) then plug in again and all is good. GE says to either raise the microwave 4" or stop boiling pasta on the stove, neither a good solution. Good luck!
Jan 28, 2013 | GE Advantium 120 Convection/Microwave Oven
I HAVE A GE MICROWAVE/BROWNER NODEL WES1384SM2SS. IT HAS STOPPED RUNNING. I CAN SET IT UP TO COOK BUT WHEN I HIT THE START BUTTON NOTHING HAPPENS.
Re: GE JES1384SF Mine quit working so I unplugged it and put a pot of boiling water in it and let the steam dissolve whatever was gumming things up. I used an electric hot plate to keep the water boiling. I let it boil for a couple of hours. I left the door 2/3 open. The microwave is working again. It is four years old and has been used every day, many times a day before it stopped working.
Jan 08, 2011 | GE JES1384SF Microwave Oven
Mirowave won't stop running; fan runs, light is on only way to shut down is to unplug unit. Model:JVM1650WH05
Sounds like the control circuitry inside is bad,,,or the relay or switching device is stuck on...If the control circuit is bad then you will need someone qualified to repair the circuit...A word of caution...if you decide to try to fix the unit yourself I will tyell you that there are very high voltages inside that can KILL. Please do not service unless you are trained in electrical safety
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm1870sk04 GE profile microwave will not shut off unless the door is open. Unplugged , pushed off/cancel continues to run with door closed. Any solutions?
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Space,aker 1800 microwave is making
You should keep it unplugged until it's fixed. If it's cooking while it should be off, that can damage the oven or even start a fire.
It's either a failed door switch or door switch mount, or a bad electrolytic capacitor on the control board, which we can repair for $39.95.
If you're hearing a fan or motor running, I'd suspect the switch. See this file for help.
If it's a buzz (like a power line buzz) then I'd suspect the board capacitor.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 24, 2010 | GE XL1800 1100 Watts Microwave Oven
Advantium microwave won't stop.
If it runs when the door is open it's a bad interlock assembly
Aug 31, 2009 | GE Advantium SCA2000B Microwave Oven
GE Microwave
maybe the problem is in the door latch switch try to replace the switch going to lights or bulb.
Jun 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE 1339BW002 Microwave stopped working
Yes, there should be a ceramic (tubular) fuse under the cover on the top side where the power comes into the microwave.
Dec 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE HVM1750SMSS Microwave Oven Logo
162 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
