Question about Singer Confidence 7467 Mechanical Sewing Machine
Model 7467. bought in april and it was working. now top and bottom threads will not form "stich". it is threaded correctly! took off face plate - nothing jamming up. machine made a clunking noise once when i began sewing.
    Master:
  • 400 Answers
Sounds like bobbin isn't inserted in the bobbin shuttle correctly. Make sure to follow arrows shown on shuttle assembly so that thread is exiting bobbin correctly. Make sure your setting is for a normal straight stitch and tensioning adjustment is set at a low number. Some machines have 100 stitches or more and two or three feet to choose from. Remove foot and use another. Experiment with settings for stitch-types and adjust them all. If machine is under guarantee, return it. Some are just BAD.
Posted on Dec 20, 2014
  • Singer Master
  • 7,365 Answers
Try changing the needle
check the top thread tension
check to make sure the bobbin is inserted in the bobbin case correctly
check to make sure the bobbin case is correctly inserted into machine
Posted on Oct 01, 2010
I tried to tighten tension on top of the macine. The bottom thread is still not stiching, it is loose and looks like a thread with little loops on it.
Be sure your needle is in correctly, the flat side of the needle should be facing AWAY from you (or the front of the machine). Having the needle position incorrect will do this.
Feb 20, 2017 | Sewing Machines
Hi. I just bought this machine and I am having trouble with my bottom stiches. I have tried every remedie but the stiches is too loose
Read this hope it helps
http://www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all
May 19, 2016 | Sewing Machines
I bought this for my granddaughter. we just tried it for the first time and it doesn't sew. It works, looks like all is going well but does not stich.
Assuming that this is the first time you use a sewing machine I'd tell you that you don't have the thread properly looped. Read the book and insert both threads in it step by step. But if you are skilled at sewing, then the machine may be defective
May 07, 2016 | Sewing Machines
Singer confidence 7467 bobbin thread issues
Have you checked that under the foot plate is clean sometimes a bit of fluff or thread collects there, and are you threading the needle the right way. check with the manual for the machine. Also check which way the manual recommends the bobbin thread is unwinding clockwise or anticlockwise. Hope this is helpful,
Sep 03, 2012 | Singer Confidence 7467 Mechanical Sewing...
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
Bottom thread lose on my Singer Confidence 7467 model
try adjusting the top thread tension one letter or number higher
till the stitch looks good
Jul 23, 2012 | Singer Confidence 7467 Mechanical Sewing...
Tension setting set on five allows top stich to be pulled out easily. Higher or lower settings seem to have no effect
Are you sure you're threading the machine up with the foot lifted ... if not, the thread may not lay properly in the tension discs and you wont be able to adjust the tension properly. Thread the machine up with two colours top and bottom and check whether the stitch is being formed properly - the two colours should pretty-much be on the correct sids of the material.
Sep 11, 2011 | Bernina Artista 170
When i try to sew after i have pulled the bobbin thread through no stiches are formed both threads are on top but no stiches are formed
Be sure your bobbin is inserted correctly. This is usually the main cause for the stitch not being made. If that's not the answer, be sure the upper threading is correct. If a thread guide is not threaded or if the thread does not go between the tension plates, this might cause your problem.And of course, make sure the needle is inserted with the groove toward you and that it is inserted completely in the needle channel. If none of these are the problem, the bobbin case may need to be adjusted or checked for burrs. I really hope this helps you. If it does, please come back to Fixya and rate my advice.
Aug 01, 2011 | Singer Sewing Machines
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Singer sewing machine stiches not forming & thread bunching
Sounds like what is called bird nests or thread nests. The top thread is not seated completely in the tension disk.
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Now, retest your machine.
Jun 28, 2017 | Singer Sewing Machines
Singer Confidence 7467 Mechanical Sewing Machine Logo
216 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
