Question about HP Office Equipment & Supplies
Have HP Pavilion a6419fh Pc and HP Officejet 5600 all in one series. I cannot get the page to print when I am on line.
  • 50 Answers
Configure browser page setup
Posted on May 25, 2008
Printer gets print command and goes through print action but no print on page. Ink cartridges indicate full.
Although "full", some ink in the path-way has dried out, and is blocking the flow of ink from the ink-tank through the ink-jets.
Try the "head-cleaning" procedure, or replace the ink-cartridges.
Oct 31, 2013 | HP Officejet 5600 series
Hp 5600 printer will not effectively cancel print
Please try to following these steps :-
1- Try to run print spool services from the services.msc
just type :- services.msc in the run command.
then restart the print spooler service.
2- Try to delete unprinted page from the print command.
3- Please download HP printing diagnostic utility for check printer problem :-
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-2&cc=uk&lc=en&dlc=en&product=3221646
4- Try to uninstall and reinstall the printer.
please install the driver from the following link ;-
http://download.cnet.com/HP-Officejet-5600-series/3000-2116_4-80627.html
May 05, 2009 | Computers & Internet
My printer screen says no connection
disconnected all cables and connected back.
Jan 11, 2009 | HP Officejet 5610 All-In-One InkJet...
New Hp Officejet 5610 All-in-one - Printing?
You may have a couple of problems. First, you say you have more than one icon in your Printers dialog box for 5600 series printers. My guess is that you installed two different drivers, one for the 5600 and one for the 5610.
Try deleting the 5600 printer icon and making the 5610 the default printer. Run the test print again to verify it works, then open a Word document and see if you can print that.
This brings me to the second issue; what exactly are you trying to print? The issue in this case, may not be the printer but an issue with the document. Some documents have a security feature that prevents printing. Try different documents (Word, Excel, etc...) and see if the problem is across the board. Post the results here.
Thanks.
Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
Printing
hi,
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
adonscott
Apr 04, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Printer not printing properly
Does it happen while printing from all the applications or from only any particular appication or from e-mail/web printing ?
Click Start (Windows Icon) - Printers Folder
Right click on the printer icon Officejet 5600 series and select properties. Click on the Advanced Tab. Enable the option Print Directly to printer. click Apply and OK. Check for the result.
Thanks
Dec 22, 2007 | HP Officejet 5610 All-In-One InkJet...
41 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
