Question about LG DLG7188 Gas Dryer
On occasion when we turn on the dryer the wheel does not turn and we hear a hum. this mostly happens when we do a second load and the dryer is still hot. In order to get the drum to turn I open dryer door and simultaneously press on button while pressing in door switch and manually turning drum.
  • 489 Answers
You have a problem with the dryer motor and it needs to be replaced.
Good luck.
Posted on Oct 04, 2010
We bought a Samsung DV419AV dryer less than a year a go. tonight my wife went down to dry a load of work close for tomorrow and set the drying cycle and pushed the start button. you can hear a hum but the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Dryers
When the button is pressed to start the dryer it begins to hum as iff the drum is stuck. It does this for about 5 to 10 seconds then shuts off. If I attempt to start it again nothing happens. sound like...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Apr 17, 2011 | Whirlpool LER7646E Dryer
Dryer motor hums but does not turn when start button is pushed
Jan 24, 2011 | Maytag MDG6000 Dryer
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
Jan 23, 2011 | GE Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
Jan 17, 2011 | Maytag Dryers
Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Mar 20, 2010 | Whirlpool LER4634J Electric Dryer
We just purchased a new Samsung Dryer model #DV218AEB/XAA the lights will come on but when you attempt to start the dryer there is a hum, the dryer does not spin, then the hum goes away after a few...
Could be a couple things causing this problem. If you can turn the durm by hand without much resistance then the belt may be too loose. This could be because the spring on the tension pully came off or the belt streached. The humming you hear is the motor spinning. If you cannot turn the drum by hand then something could be stuck between the drum and the frame of the dryer.
I would also check that the dryer is wired correctly, because low voltage could be causing the motor to hum but not turn.
Dec 23, 2009 | Samsung DV218AEW Electric Dryer
When i turn the on switch i hear a humming as if it is going to start but it does not. my dryer brand is Frigidaire FEQ 332 E s
Depending on the hum you hear (if you hear the sound and it keeps humming) the belt that connects the motor and the drum is probably broken.
If the hum only happens when you turn the on switch, the motor has probably failed.
Aug 31, 2009 | Frigidaire GLEQ642A Electric Dryer
The dryer will not tumble
do you hear any humming noise? does the heat come on?....no noise. most likely is a thermal fuse....small white fuse usually with two blue wires. humming means broken belt, bad motor or something stuck in blower wheel.
Jun 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Open Questions:
LG DLG7188 Gas Dryer Logo
51 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
