Question about Danby DPR2262 Top Freezer Refrigerator
How do you adjust the flame on a propane refrigerator?
RM2652 cools great on gas and 110 but will only cycle on and off in 110 mode. Once gas is selected, it will never cycle off.
These dual service refrigerators are somewhat tricky. Did you check the gas system for any carbon buildup around the flame/burner area. If the flame is not the proper size it will not get cold enough to shut off. Clean all carbon/dirt from the flame area and check again. Propane causes deposits after a while.
Oct 07, 2014 | Dometic RM2652 Refrigerator
How to adjust flame on propane freezer
You do not adjust the flame on the freezer. It is a preset flame. The orifice is a man made ruby that is laser cut with a spiral through it. Running a fine wire through the orifice will damage the spiral cut and cause the flame to fail. Blowing compressed air through could dislodge the ruby and remove it or cause it to be at the wrong angle which will cause the flame to fail. The way to clean the orifice is by soaking it in denatured alcohol then allow it to air dry. The burner tube also has preset slots that should not be tampered with other than making sure that they are not clogged. The igniter also serves as a flame sense monitor and should be approximately 1/8" above the burner tube.
Jun 24, 2014 | Dometic RM2652 Refrigerator
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Mar 28, 2014 | Dometic RM2652 Refrigerator
Recently purchased a whirlpool gas range from Lowes "return,discounted aisle" I asked had it been converted to propane and they said yes it had. Wife is overly concerned how do you know they can...
Their is no marking or anything easy to determine that.....however natural gas is lower pressure that propane so if you were using propane and it was set to natural ALL the flames would be huge since it would be operating on the higher pressure while it was set for the lower pressure which would result in a flame thrower from each burner and soot so if the flames are pretty normal size despite the small adjustment for the simmer i believe its set to propane.
GENE
Sep 08, 2011 | Whirlpool SF310PEK Gas Kitchen Range
I bought at Dometic propane/ electric fridge for my cabin last year. It has not run properly since. The fridge will light and run for a while with a blue flame but sometimes in the idle mode it goes out....
I have to ask, what is idle mode? I've never seen one that runs on idle mode, in a RV in 15 years. Has anyone used a manometer and tested Inches of water column in propane supply to fridge, as well as other appliances?
Any I've seen run on propane, are either on, (flame present, or off, no flame present.) Flame goes out completely when not calling for cool.
Jun 13, 2010 | Dometic RM2620 Refrigerator
I turned my propane fireplace on and it set my smoke alarm off. We have lived here for three years and never had this problem before. Please advise.
check to see if the flame is pure blue. if not you have incomplete combustion letting CO or CO2 into the room. The flame will look yellow if this is the case. An orange flame indicates dust and dirt around the burner assembly. If it is yellow, the should be 1-2 set screws on the back of the burner assembly that will let you adjust the primary air being mixed with the propane.Adjust until you get blue flame and tighten set screws.
Dec 05, 2009 | Vanguard International Blue Flame - Large...
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
Adjusting goodman propane burners
Yellow flame can also mean inadequate gas pressure. Do you have a manometer? If not, call your gas company for a check.
Oct 09, 2008 | Goodman GMS90703BXA Heater
Burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Jan 08, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Danby DPR2262 Top Freezer Refrigerator Logo
252 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
