Question about Intermatic Inc. ST01C Digital In-Wall Timer
Utilitech Self-Adjusting Wall Timer- #0192773. Unable to program timer. The instructions are so small it is hard to read them
Utilitec 0192773 is also listed as LW60419
1) Has optional daylight savings plus dawn to dusk programming
2) Electrical wiring must be connected in order to program timer. This is because timer is powered by electric circuit (instead of battery).
3) Program choices:
-Individual days MO TU WE etc
-All 7 days of week
-Weekdays
-Weekends
4) Large manual + wiring tips:images load slow with dial-up
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
5) Enlarged manual
-Click on image to enlarge
-For more size, hold down Ctrl key on keyboard and use scroll-wheel on mouse
Posted on Oct 01, 2010
  • Anonymous May 06, 2011
    two thumbs? The answer does everything except drive to your house and program the timer.
2 Suggested Answers
  • 10 Answers
SOURCE: Utilitech Self-Adjusting Wall Timer- #0192773.
The day of the week display is very high in the display. You may not even see it if you don't squat down a little. Once you get the point where the on time is showing but not blinking, pressing the or - keys will cycle you through thedays of the week an then to where the entire week is displayed or only part of it. At first i did not even know it was happening because the white housing obscires the days of the week from normal viewing position. You will have to repeat day of the week selection again on the off time just as above. This timer should allow you to use the multiple settings to make a weekday setting and a separate weekend setting,
Posted on Sep 30, 2010
Installed Utilitech 192773. The lights works, the backlight display comes on light blue but there is not numbers on the digital digital display
Reset timer, and see if that fixes problem
Use toothpick or paper clip to press reset button, or refer to instruction sheet, or copy following link.
I have tested this utilitec timer, and using reset button will repair most problems.
If not, then Timer has 1 year warranty against defect, but it is easier to buy new timer at Lowes, and return defective timer in new package and report timer as defective.
Jul 29, 2012 | Hardware & Accessories
INSTRUCTIONS FOR UTILITECH SELF-ADJUSTING WALL TIMER MAKE NO SENSE! iNSTALLED, BUT HAVE TO TURN PORCH LIGHT ON MANUALLY EACH DAY; ALSO COMES ON SOMETIMES IN THE MIDDLE OF THE NIGHT! HELP!
1) Sounds like you have timer wired correctly.
The wiring is confusing for many people, so it's apparent you're a quality electrician.
2) There are no repairs for defective timer, but timer can be reset using reset button.
Reset will clear program conflicts and overlaps that cause timer not to operate as expected.
3) Model number of Utilitec timer is not given, so expert has to guess which fork in the road you want to choose.
4) If you have 0192773 timer and want do-it-yourself solution, open following link for larger print and photo illustrations that make programming easier.
5) If you have 0141224 timer, then open following link for larger print instructions.
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
6) At any point, you can add a comment and ask very specific question about any part of the instructions for either in-wall Utilitec timer, or any Utilitec timer, or ask a question about almost any 60Hz timer on the market today.
That comment sends an e-mail, and then I will respond.
I have tested both Utilitec in-wall timers.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 31, 2011 | Hardware & Accessories
I have a utilitec self adjusting wall timer #0192773 that stopped functioning. The led display is blank. I tried to re-set per the instructions, but nothing. I've confirmed power to the timer. Does this...
If resetting timer does not restore functionality, and timer has power, and you checked that LIGHT BULB is good, then timer has gone bad.
To double-check circuit, replace timer with ordinary on-off switch and see if it works.
Warranty: buy new 0192773 timer at Lowes, and return broken one inside new package.
Apr 21, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a Utilitech Self-Adjusting Wall Timer- #0192773 that will not hold it's program. It worked fine and then I had a power outage after replacing the standard bulbs with CFL bulbs. Now I set the...
Manual for this timer says to reset timer when encountering a problem.
Just press reset button for 3-4 seconds, and then re-program timer using instructions on following page.
I have tested this timer, and it is a good timer with typically difficult programming because of Astro option, but all these in-wall timers have 1 year limited warranty.
You can buy another one at Lowes, and then return defective one in new package if necessary.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Feb 25, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I can't read the instructions that came with the utilitech #0192773 timer. The print is too small. Please e-mail me readable instructions for programing.
I couldn't find the instructions online, however, you can go to just about any Commercial copying place and get an enlargement of the instructions that came with the device for a nominal fee.
Sep 12, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Only 2 black wires on current switch - Utilitech 0192773 has 4
Webpage explains wiring and has large print:
Mar 07, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
2,271 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
