Question about GE DWSR463EGWW Electric Dryer
The timer knob is stripped out - GE DWSR463EGWW Electric Dryer
  • GE Master
  • 7,482 Answers
Replace the timer knob...it is cheaper than replacing the dryer.
Go to: partselect.com/
You should be able to find the replacement knob for your timer
Please rate me
Posted on Sep 30, 2010
General Electric WHDSR209DWW Top Load Washer. Timer works but has lost proper synch with knob and skirt. Can force timer to a position that will run the machine from an unknown starting point. When knob...
Hello:
Its either your knob is stripped or the timer itself is..Most commonly its the knob assembly that's bad.(part# WH01X10061) I would try it first since the knob is only around $7.00 where the timer is around $140.00or so...
Good luck
Jun 04, 2017 | General Electric WHDSR209DWW Top Load...
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
How do I replace the "notch" (which is stripped) that is used to align the knob to the actual timer? This is on my GE Washer
It depends on which piece you are talking about. If you mean that the inside of the knob itself is stripped you just need to grab a new know off a similar machine or get a new one from a parts store (pretty cheap).
If you mean that the metal piece sticking out of the timer is stripped then you need a new timer since that piece cant be replaced individually. You can get a new one from an appliance parts store, just take them the model number of the machine and they can look it up and most likely tell you how to replace it as well.
Dec 13, 2009 | GE WDSR2080D Top Load Washer
The time knob on my Sunbeam Rocket grill stripped out. So I can't set the time. Is it possible to get a new knob?
I thought mine was stripped, but after pulling the plastic knob off, it was only the inside of the knob. I just use a screwdriver to adjust the timer until I can get the knob replaced.
Jun 28, 2009 | Sunbeam Rocket Grill RG12
Timer knob doesnot move dryer will not turn off.
Clean the fabric softener off the metal strips located under the filter housing inside the dryer. If **** gets on them then they wont send a signal to the dryness board and advance the timer motor. Resistance is monitored between them 2 metal strips as yer wet clothes tumble in the dryer. Wetness is detected and the motor gets a no go. When the all clear is signaled up then they is happy motoring to the finish line.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 15, 2009 | Dryers
Can not get the upper right dial off. It needs to be replaced.
remove console by taking 2 screws from the rear of it out, timer knob can be removed by squeezing pin at the center of the timer and pulling knob forward. Probably the timer needs replacing
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Stripped start knob
That would be the timer assy You may need to replace entire assy and knob you could try a strong 2 part epoxy and allow to dry min 24 hrs at room temp.
Dec 11, 2008 | GE DCSR483EA Electric Dryer
GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Mar 04, 2008 | GE WDSR2080D Top Load Washer
GE DWSR463EGWW Electric Dryer Logo
268 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
