Question about Kenmore Washing Machines
My kenmore series 80 needs a push start to spin i took it apart and replaced the clutch even though it looked brand new (i had already bought it) still have the same problem the coupler is good any thoughts?
  • brianlwilson Oct 01, 2010
    kelly i am not real good on computers but mine blocked both of the links you sent me i am interested in knowing about the clutch liner and possible brake problems thanks,brian
  • Kenmore Master
  • 3,361 Answers
A garment may be stuck between tubs.
Posted on Oct 02, 2010
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
When you replaced the clutch did you also replace the clutch liner? Also is the unit completely draining all the water in under 90 seconds? Both can cause the problem that you mentioned of having to push the tub to get it to spin. The cam driver can also cause the problem.
I hate to just post a link but this link is so extensive and informative I really believe it will help you resolve your spin problem:
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
Not the videos also about the motor coupler. One side of the motor coupler can be fine and the other side can be broken.
Most of the time only one side fails were the 3 drive pins shear off. Also there can be a brake problem.
Also the file below is the training manual that is better then the service manual for inspecting spin components
Go to this page and download file 787772 #4.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738?OpenDocument
Take a look at the links and if you need help after that I will help you.
Kelly
Posted on Sep 30, 2010
  • Kelly
    Kelly Oct 01, 2010
    Hi the second link you should be able to download by rt clicking and then save as. If it comes up and says blocked for yur protection there are 2 ways to make it work. On the very bottom bar of your screen 1/3 way in from the left you will see a circle with an line though it. Rt click that and choose temporarily allow popups. The other way is when the bar pops up on the top of the screen do not choose the X click the bar only and aloow or ok the site.
    With out you seeing the pictures it is going be really hard to explain because there are so many position sensitive things to verify as far as the cam follower, that acuates the brake and the clutch liner. I will repost in a different format that allows video afer I send this.
    Kelly
  • Kelly
    Kelly Oct 01, 2010
    Trying now to add video links here:
    Here is the whole play list for your washer.
    The one you need is near the bottom of the page and is 3:55 secs long. http://www.youtube.com/view_play_list?p=...
    This is the actual video. http://www.youtube.com/watch?v=veP71xdNn...
    When the transmission is pulled take a look at the white cam follower assy for size and position. That follower is what releases the brake. If the tab is broken or worn excessively the brake will either drag or not release. Also at the 4:40 second mark watch closely at the inspection you need to do.
    Around the 6 min mark you see him lifing off the clutch lining. Just watch the installation checks when he puts it back on.
    I think this will be a great help to you in sorting out why your washer needs a push to spin.
    The video is better than words for sure. I really don't like to just post a link but in this cause it is pretty much un-avoidable.
    Kelly
Kenmore washer wont spin
Transmission parts that would cause that are the clutch and the spin tube. Also an article of clothing wedged between inner and outer tubs could cause it.
Nov 15, 2017 | Kenmore Washing Machines
Hello, I have a series 80 washer. I replaced the coupling and the washer spins and drains but doesn't agitate. The agitator cogs seem fine. The timer hums and I smell a burning oder. Timer or clutch? HELP!
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
(The clutch is only used during the spin mode)
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight gear oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
Dec 12, 2010 | Kenmore Washing Machines
80 Model will spin sometimes -with help- but never fast
Likely the out of balance sensor is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
My 80 series 110-23812-100 type 3. wont spin the tub during rinsing and i already replaced the plastic coupler
It's more than likely the clutch. Since you already replaced the motor coupling, it can only be the trans or the clutch and my guess is the clutch since the clutch and motor coupling are the weak links in the system.
Dec 06, 2008 | Kenmore 24902 Top Load Washer
Kenmore Series 80: Loud clicking at spin cycle
sounds like spin tube bad will need to remove basket and gearcase to remove it
Sep 30, 2008 | Kenmore 20172 Top Load Washer
Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Dryer will not start
my kenmore dryer 80 series wont start the start switch just buzzes and the drum does not turn i put a new switch today vacuum it and check all belts they seem fine dont know what else to do
Jan 08, 2008 | Kenmore 73952 Gas Dryer
Washing Machines Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
