Question about Braun Syncro 7680 Electric Shaver
Where to get and how to replace the shaver switch on 7680?
  • Braun Master
  • 1,612 Answers
The switch is part of the outer case and can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-body-housing-select-models-p-811.html
To replace, you will need to gently pry off the cap that surrounds the cord hle on the bottom. Once removed, the side grips will pull away easily revealing 4 screws on the back. Remove screws to take the bask of case off and then lift out the 'guts'. Reassemble in reverse order
Posted on Sep 30, 2010
  • jerzy_las58 Oct 01, 2010
    Guru Braun:
    Thanks for the valuable info. Will get the part if available and start working!
    Jerzy L.
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 95 Answers
Braun Syncro 7680 replacement foil and cutter is Braun Series 3 Combi 30B outer foil and cutter replacement pack (7000/4000 Series)
Posted on Jan 08, 2013
  • 4 Answers
SOURCE: I have lost my instruction and cleaning
Here are the instructions for a #7680 Shaver. http://www.service.braun.com/line/SH/S5491/S5491_9_NA.pdf
Posted on Apr 26, 2009
SOURCE: shaver shows "oil" How do I do so? nothing in owners manual .
http://www.service.braun.com/home.asp?rg=NA&c=US&l=GB&typ=ui&s=&seite=&sString=
The above in a link to brauns website. You can view or download the user manuals for all their products.
Steve
PS. It just says to put some oil on your finger and apply to the outside of the foil.
Posted on Jun 19, 2009
brector3
  • 1612 Answers
SOURCE: The stand on my 7680 doesn't clip into the shaver
the arm portion of the base can be replaced to fix this. part can be purchased at shaveroutlet.com
Posted on Jan 16, 2010
Testimonial: "I've just installed the arm portion of the base which I ordered from shaveroutlet.com as you suggested. It's tricky to replace, but it worked!"
SOURCE: SyncroPro 7680 shaver cannot move
7680 shaver wount turn off.
Posted on Jan 15, 2011
ginko
  • 19396 Answers
SOURCE: How do you replace a
Hi.
The batteries are inside the shaver. You need to disassemble it if you want to replace the battery:
Regards.
Ginko
Posted on Apr 19, 2011
Replace battery on synchro 7680
You will find videos for dismantling the shaver as well as instructions for replacing the batteries at shaveroutlet.com. For these videos and correct batteries, see link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-replacement-battery-aa-nimh-p-108.html
Mar 01, 2013 | Health & Beauty
Excessive vibration with Braun razor
Most likely, the oscillator in the drive unit is broken. You will find this part for model 7680 at shaversource.com. See link below for product and helpful disassembly video
http://shaversource.com/shaver-replacement-parts/braun-7000-series-syncro-motor-drive-unit-p-110.html
Jun 09, 2011 | Braun Syncro 7680 Electric Shaver
I have a Braun 7680, and the switch won't work - it is stuck on "on".
Most likely, the mechanism is broken and will need replaced. The switch is part of the trimmer assembly which comes attached to the outer casing. You will find a replacement at shaveroutlet.com. See link below
You will also find disassembly tutorial at the link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Nov 17, 2010 | Braun 360° Complete 8985 Electric Shaver
My Braun electric shaver model 7680 has stopped functioning probably due to a dead battery ( I had it for years). A service center is asking in excess of 60 dollars to fix it. Battery and mother board...
If the shaver is completely dead and the charging lights no longer illuminate when plugged in, the circuit board will need changed. If they still illuminate when plugged in, you can just change the batteries.
You will find the batteries and also the circuit board with batteries at shaveroutlet.com. You can order which you require. See links below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-circuit-board-with-batteries-select-models-p-772.html
There is a tip on the battery page for easier installation
shaveroutlet.com has an instructional video that shows you how to disassemble the shaver at the link below. It's the 4th video down
http://shaveroutlet.com/video_tutorials
Oct 14, 2010 | Braun Syncro 7680 Electric Shaver
I have lost my instruction and cleaning manual for Braun electric shaver #7680 and need to find replacement.
Apr 26, 2009 | Braun Syncro 7680 Electric Shaver
Braun Syncro 7680 Electric Shaver Logo
310 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
