Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Got a troy built 21" mower with B&S 650 190cc motor.. seems to be fuel starvation..we've replaced the spark plug, and the fuel and air filters..no luck.. electric starter cranks just fine, but will not get engine started.. the pull rope gives the same thing..just seems as though no fuel is getting to engine.. does this model have a carburetor?..if so, where?..the owner's manual isn't worth a damn, and the grass is getting higher.. and higher.. and...
  • Briggs & Str... Master
  • 7,482 Answers
Check your fuel filter if you have one.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Testimonial: "great reply.. it WAS a fuel problem..namely, costco gas..fixed carb, now only use shell, chevron, or mobil gas..along with fuel stabilizer. THANKS"
What caused Troy built Tractor (pony) stopped running sudden
Replace HT leads with silicone ones, u shud not get any shock from old ones un less they are breaking down,unless they are leaking , u shud now get a big blue spark if not then also replace coil hope this helps
Apr 26, 2014 | Troy Garden
My Briggs and Stratton lawnmower engine won't start. Checked for air, spark, and fuel problems.
Before doing too much more i would pull the flywheel off and check the key has not part sheared.
Jan 28, 2013 | Troy Bilt 5.5hp Self Propelled Mower
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
I have a poulan pro self propelled mower that is not running smoothly. The motor speeds up and slows down and it seems like it is going to die. I replaced the spark plug, cleaned the air filter and put...
Hi, your problem is caused by a fuel starvation issue. Remove the carby, disassemble, remove all jets and blow them out with compressed air. Put it all back together exactly as it came apart. Hope this helps, regards Phil.
Jul 02, 2011 | Poulan Pro 22" Self Propelled High Wheel...
How to change the oil in my troy built pont where is the drain plug
Not sure what a pont is, or what motor you have, but on some of the Troy built small engines from Honda the geniuses designed the motor with no drain plug. You have to tilt or flip the engine over to drain oil out the filler
Feb 24, 2010 | Troy Garden
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy built 6.5 21" lawn mower won't start
take the carb bowl off it may have water in it , that will make it not run
Aug 15, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a troybuilt push lawnmower with a honda motor, I was wondering where the oil plug was where I can drain the oil.
It is under the mower, you will need a 3/8 ratchet and extension to take it out...make sure NOT to tip the mower over, you will have to raise it, but make sure the spark plug end stays up!!!
Apr 25, 2009 | Garden
My Troy-Bilt 21'' 3-in-1 self-propelled mower will not start
Next time keep the carburetor up...tipping it down will allow oil to go where it's not supposed to. For now drain out the remaining oil, replace the air cleaner and remove the spark plug. When the plug is out pull the engine over a few times. It's possible that there is oil in the cylinder and this will help clear it out. Replace with a new plug and try. If this doesn't work, repost.
Apr 11, 2009 | Troy Garden
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
512 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
