Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite model 110 42926 200, I would like to know why the liquid detergent runs into the tub when I pour it in the dispenser tray? A little info will be appreciated.
5 Suggested Answers
  • 209 Answers
SOURCE: water in softener dispenser
the conditioner works by siphoning out when the water from filling mixes with it, the excess water then drains away the same way, when you took the drawer out, you must have either not cleared all the powder or not put it back together properly, if it worked before it has to be something you have done, sorry, just keep trying different ways and double check to see if all bits have been cleaned properly if i have helped please rate me
Posted on Sep 17, 2007
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Posted on Oct 07, 2008
SOURCE: Whirlpool Duet dispenser problem
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
Posted on Apr 03, 2009
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
Where do i put liquid detergent in top stacking may tag older model
Just pour the liquid/powder into the wash tub prior to loading clothes... this machine does not have a detergent dispenser...
Jul 06, 2014 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite heavy duty king size top loader water will not stop running to the liquid detergent dispenser even when the tub starts filling Causing the machine to over flow
could be the water valve not closing properly, try unplugging the machine see if the water stops if not replace water valve. Also check pressure hose for cut and pin hole thx
Mar 01, 2014 | Washing Machines
My Kenmore Elite front load steam washer started pouring water from the detergent dispenser
It might be needed to remove the panel to get access to the tubing , please check this link for tips to check this out: dispenser
Jul 05, 2012 | Kenmore Elite Washing Machines
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My sister pours a lot of liquid softener into our Kenmore Elite front load dispenser. I said to only use 1/4 cup as recommended. Will using too much fabric softener cause problems?
YES!! This machine uses an average of 14 gallons of water per load as compared to 40 gallons for a top load!! Less water means less detergents!! Excess detergent and softener can create build up withing the machine that will cause unpleasant odors and eventually rear bearing failure.
Jul 03, 2010 | Kenmore Elite 45986 Front Load Washer
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Kenmore elite washer model 20952992 pouring water
We had the same problem. The bleach dispenser tray is located on the drum below the bleach storage pan. The dispenser tray has very small holes that were plugged by rust from the hose clamp that attached the dilution water supply hose to the bleach storage pan. I removed the top of the washing machine to discover the problem, but it may be solved by attaching a flexible tube or small hose to the end of a vacuum cleaner hose and cleaning out the dispenser tray. There is room between the dispenser tray and the storage pan and is located in the front right corner.
Dec 10, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
76 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
