Question about Sony STR-DE698 Receiver
When i change the channel, the sony reciver kicks off and says "protection"- why is it doing this? The reciver is hooked up to a Bose surround system.
    President:
  • Sony Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Oct 01, 2010
Bose Life style 535
I had same problem once,i bought a new HDMI CABLE the salesman told me that my HDMI cable has loose grounding.
Feb 04, 2014 | Bose Lifestyle 38 System
Just purchased Sony DA5800 ES reciever will my Bose 901 speakers work with this? Need help
Bose 901 speakers are designed to use with the Bose equaliser patched between the pre-amplifier out and power-amplifier in of your receiver. Having said that, Bose did not invent EQ, neither is EQ a mystical process. Not sure which series 901s you are talking about, but I would definitely be experimenting with the built-in EQ supplied with your Sony DA5800 ES. The manual says you have +/- 10 dB of adjustment for treble and bass for each of the surround channels. That is not really adequate in my opinion, not only would I be seeking +/- 15 dB, but I would also like to be able to apply those adjustments at frequencies chosen by me, not just 'treble' and 'bass' To use the Bose EQ, it needs to be patched between a preamp output and power amp input. The Sony DA5800 ES has preamp outputs, so you could use these (Note that the built-in EQ is disabled when using these outputs) In this case you could either feed the signals back into the Sony (post Bose EQ) perhaps using a different 'Zone'. As an alternative option, you could power your 901's with a stand-alone two channel power amplifier. Then you get the full benefit of the Bose EQ as well as the surround sound from your Sony (front L+R speakers off) It all sounds like a lot of fun. Happy listening! Cheers, Don.
Nov 28, 2013 | Bose 901 VI Main / Stereo Speaker
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
Can i hook up the bose wireless reciver for the rear speakers with a onkyo reciver
I don't see why not. Use any record out or if you can rear pre amp out connect to the input on the bose unit.
Oct 09, 2009 | Bose Acoustimass 16 Speaker
Best amplifier for bose 901 VI speakers
By all-in-one amplifier that handles the surround I think you mean all-in-one receiver or preamp. Amps are just big dumb muscular power supplies for speakers.
The source control and digital decoding could be handled by a modern AV receiver with multichannel analog outputs for driving separate amps or you could get a digital AV preamplifier/control unit functionally like this Adcom. Prepare for sticker shock.
http://hdtvdreams.com/Adcom-GTP-870HD-7.1-Multi-Channel-Processor/Preamplifier-GTP870HD.aspx
Understand that EACH PAIR of Bose 901's will require its own DEDICATED two channels of amplification AND someplace to jack in its Active Equalizer - between the line level source and the power amp.
Conventional speakers can probably run off the receiver's amplifiers since they don't/can't/must not have the Bose Active EQ in line with them.
Having a single pair of 901's plus a passive subwoofer or two in the same room for accurate 6- or 7.1 surround would require at least four stereo amps or some combination that adds up to 8 channels.
In my own system I have a Pioneer VSX-36TX Receiver (with 5 potential channels of amplification for Left, Right, Center, two Surrounds) doing light duty as the control and routing center but ONLY driving the Center (two Kenwood 777's) and Surround speakers (Bose 301's). I have a Carver 5-channel amp pushing the Bose 901 Front speakers (100Wx2), two dbx Subwoofers (110Wx1) and the Bose 301 Rear Surround speakers (60Wx1).
You could probably get by with a powerful 2-, 3- or 4-channel amplifier to push the 901's and subwoofer(s) as I did. It's the cheapest way out if you get a decent AV receiver. Once you set up the levels and delays the receiver does all the thinking and controlling for you.
Mar 18, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 hook up
Assuming you really want to have a working surround system you will need a separate stereo amplifier for the 901's to accomodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's. However, the TX-SR606 doesn't provide power for a Subwoofer, should you decide to get one, so you would need another amplifier channel for that, too. Therefore, you might look around for a powerful 3- or 4-channel amplifier so you could drive the Sub, too.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ';s Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
A seperate subwoofer channel on the amp could be used. Just run a single RCA channel from Sub OUT to one available channel IN on the amp and attach the subwoofer to it. Two would work, also. That's what I do. You could use a 1-2 RCA splitter to feed two avaailable channels on a 4-channel amp. The iterations are many. Have fun.
Feb 28, 2009 | Bose 901 VI Main / Stereo Speaker
How to hook up bose series 2 eq to onkyo tx sr 875 receiver.?
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! I see on the SR875 there are Pre Audio OUTS. This is easy.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Jan 07, 2009 | Bose 901 VI Main / Stereo Speaker
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Jan 21, 2008 | Audio Players & Recorders
My 2003 STR-DE995 goes into "PROTECTER" mode
hi roy for starters hooking up more then 1 speaker to 1 input makes the total impedance higher\lower then the reciver "sees" there for u r causing the amplifier work hard and warm it up for no reason attach each speaker to 1 inlet look on the speaker for level of resistance (4 Ω, 8 Ω) and adjust the reciver for that level in that inlet if u want morn power ull have 2 connect the 2 amps in line as you sed, although the Bedini is "old-school" im sure it will do just fine and then u can crash ur whole house down from endless power... its difficult to say without any parameters what kind of connection will be the best result, so just try them all and see what u like the best keep in mind that loud music is hearting ur ears and if ull keep up this way ur wont be able to hear your child not to say when you will b older.... good luck windman
Jan 09, 2006 | Sony STR-DE995 Receiver
Open Questions:
Sony STR-DE698 Receiver Logo
226 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
