Question about Kenmore 74112 Gas Dryer
Dryer gas the dryer stop to hot works no hot
  • John Rodgers
    John Rodgers May 11, 2010
    not clear on what you are asking
  • Kenmore Master
  • 43,501 Answers
Hi, If you have a gas dryerdryer gas - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troudryer gas - 2_bing.gifg2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 29, 2010
  • 209 Answers
Check the gas dryer sensor...
Posted on May 05, 2009
  • Ryan Beltran
    Ryan Beltran May 05, 2009
    check thge gas dryer sensor.
2 Suggested Answers
SOURCE: kenmoore 110.79902890 gas dryer
u may need to check the heating elements inside , or electrical connections to the heating elements
Posted on Oct 22, 2008
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
Gas Dryer not working properly
bad thermal sensor needs to be replace. But not available. sorry
Jun 07, 2012 | GE Dryers
My gas dryer all of a sudden just stopped getting hot. it runs but just does not get hot.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Whirlpool WGD5600S Dryer
Cold dryer
if the dryer runs normal for the first 15 to 30 minutes you have bad gas coils located on the top of the gas valve,take out the 2 phillips screws,remove the top cover and change out the gas coils.when the coils are failing they will work until they heat up then they stop letting the gas come into the dryer,when they cool down then they will work again.change out the gas coils part number 279834
Mar 27, 2010 | Kenmore 73952 Gas Dryer
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
HEAT WORKS FOR AWHILE THEN STOPS
coils on gas control get hot and stop working you will need to change them...thumbs up
Aug 10, 2009 | Whirlpool LGR5636L Gas Dryer
THE DRYER IS NOT GETTING HOT
Hi
Please check the following things that could stop a gas dryer from heating:- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 25, 2009 | Whirlpool GGW9250PL Gas Dryer
My dryer will not get hot
My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
Dec 15, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Maytag Gas Dryer SDG515DAWW - heating stopped
if it dont come on in 30 secs replace it
Dec 30, 2007 | Maytag MDG2706A Gas Dryer
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Kenmore 74112 Gas Dryer Logo
337 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
