Elaborate on the concept of production drawing and inspection drawing
Production drawing and inspection drawing
Posted on Oct 18, 2010
  • sristi077 Oct 28, 2010
    i wish if i cud get d answr.. bt no replies.. very bad
8756 machine freezing up and icecream to thick what can it do to change problem
You can adjust the viscosity.
In soft serve and frozen yogurt machines, the logic board X36641SER2Refurbished Gen 2 Logic Board This item is sold with exchange...measures the viscosity of the product by monitoring the amp draw of the beater motor. When the machine reaches the set point, it cycles off and the product is ready. In auto mode, you can only adjust product viscosity, temperature in the freezing cylinder is not monitored.
The power board measures the amp draw. L1 power supplied to the beater motor goes through the power board on the beater terminals. Single phase and three phase units use the same Softech control, so the power board allows for different amp draw ranges. A jumper on the power board determines the amp draw range. Place the jumper on the pin that corresponds to the amp draw of the beater motor when the product is at the desired viscosity.
Setting Viscosity Adjustment
1. Place an amp probe on one of the L1 leads on the beater terminal on the power board.
2. Turn the viscosity adjustment screw to the "MAX" position.
3. With the freezer properly primed, press "AUTO".
4. During the freezing process, draw samples and inspect the product appearance. When the desired product viscosity and appearance is achieved, note the beater amperage.
5. Press "AUTO" to cancel the refrigeration cycle.
6. Using the chart, set what range the beater motor amperage falls into and place the jumper on the corresponding pin.
Viscosity Control Chart
2.4 pin - 1.2 amp to 2.4 amp
5.0 pin - 2.5 amp to 5.0 amp
8.0 pin - 5.7 amp to 11.2 amp
7. Press "AUTO". When amperage reaches the noted draw, turn the viscosity adjustment screw SLOWLY until the unit cycles off.
8. Draw several samples to verify the product and amperage when the machine cycles off remain consistent.
Adjusting Viscosity
To increase viscosity, or make the product harder, turn the dial clockwise towards maximum. Important: The dial only turns a limited amount if it stops turning do not force it.
To decrease the viscosity, or make the product softer, turn the dial counter-clockwise towards minimum. The dial only turns a limited amount do not force it once it stops.
We recommend you only turn the dial about 1 hour on the clock, at a time. Once you have made your adjustment, pull the handle to start a new cycle, when the machine cycles off check the product again.
adjusting viscosity on taylor frozen yogurt machine-5jpt2eusobswb402obrm5sjf-2-0.png
Jun 06, 2017 | Ice Cream Makers
Engine-Battery
Alternator tested 'On Vehicle' of 'Bench Tested' ??
I recommend begining with a scan,followed by our shop's standard fault tracing procedure....
INSPECT BATTERY ELECTROLYTE LEVEL
INSPECT BATTERY RESTRAINT
INSPECT BATTERY CABLES/TERMINALS
****LOAD TEST BATTERY,_______VOLTS @ 150 AMPS (Min SPEC 10.2 VOLTS @ 150 AMPS.)
TEST STARTER AMP DRAW,______AMPS INITAL,_____
AMPS SUSTAINED.
****INSPECT BELT(s),
****TEST ALTERNATOR OUTPUT,_____AMPS @ 12 VOLTS @ 2500 RPM (SPEC ______ AMPS.]
****TEST FOR DRAW,______(MAX ALLOWABLE 350 Ma),
Jan 18, 2014 | 1998 Ford Mustang
SAKAR MAXIMO CONCEPTS MAX30722 WHERE DO I FIND AN INSTRUCTION MANUAL?
You might try Google or etc, search "PDF owners manual " followed by the name of the product.
Dec 23, 2013 | Sakar Maximo Concepts MAX33722 Emergency...
WRONG KEY NOMBER
Not Get it..Would you elaborate please?
Jan 09, 2013 | Microsoft Office Professional 2007 Full...
Need a user guide for Binatrone phone2310 system400
Please download the Binatrone 2310 User Manual from the link below :
http://www.binatonetelecom.com/binaries/content/assets/binatone/products/digital-corded-and-cordless-phones/concept-combo-2310/pdf/concept-combo-2310-corded-ug_uk-btp_v04-dec27-07.pdf
Feb 18, 2012 | Cell Phones
Whirlpool DU980QPDB3 will not draw water or start wash cycle.Time appeard to work and heat is felt during cycle
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jul 21, 2010 | Whirlpool 24 in. GU980SCG Built-in...
DIGITAL CONCEPTS 7.1 MP DIGITAL CAMERA
Check if the lens problem is covered in the 1-year warranty:
http://www.sakar.com/pdf/1_year_warranty.pdf
If so, contact support...
Sakar Digital Concepts:
Phone: 1-877-397-8200
Email: support@sakar.com
Oct 14, 2007 | Canon PowerShot SD600 Digital Camera
Computers & Internet Logo
190 people viewed this question
David Payne
David Payne
