Question about Whirlpool LGQ8000JQ Gas Dryer
Heat suddenly stopped everything else seems normal
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
This is a FREE answer, Please rate me
Posted on Sep 30, 2010
What is causing my pressure washer engine to stop hard/suddenly?
Your engine is experiencing a heat seizure... the piston sticking in the cylinder as it expands under heat with poor lubrication.
May 02, 2017 | Garden
Dryer quit heating suddenly.
The fuse is located on the blower housing and if it was blown the dryer would not run at all. The limits is mounted on the heater housing and that could kill the heat as well as a blown heating element. I worked on a similar dryer not long ago with a heating problem and did a video:
DRYER NO HEAT
Jul 08, 2012 | Dryers
Everything seems to be working except it won't heat anything it just suddenly stopped heating.
Did anything spill or blowup inside? Remove the glass tray and be sure all is clean and dry.
If something did blow up (food or liquid), find the small mica window on the inside, and carefully remove it, clean up, dry off in the cavity too, and replace it.
Try to use. This has fixed 3 different microwaves for me. Hope it helps you.
Nov 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Profile Spacemaker XL1800 is not heating my food all of a sudden. Everything else like turntable, electonic display, fan, timer etc. all seems to work as normal. What do you think is wrong?
This could be as simple as a loose high voltage connection or somthing more serious, I would suggest asking a qualified technician for a quote to repair.
Jan 07, 2010 | Microwave Ovens
Appears normal
ya this is the same problem i too had...everything will seem to right but the part required for heating might be damaged internally...try changing tat...here i did the same...
Sep 19, 2008 | Frigidaire GLMV168K Microwave Oven
Microwave not heating up
that has happened to me twice, the only thing that you can try is to change the setting to make sure that its not on DEFROST setting, and if this is fine, they I recommend U to get a new Microwave. :)
Feb 10, 2008 | Microwave Ovens
GE Microwave doen't heat any food or liquids
PROBLEM MAY BE A RELAY ON THE CONTROL BOARD OR MAY BE A LOOSE WIRE FROM THE HV TRANSFORMER CKT.
Sep 06, 2007 | GE JVM1660 Microwave Oven
Whirlpool LGQ8000JQ Gas Dryer Logo
110 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
