When it rains hard and there is a lot of wind the rain gets into the chimney and drips through a ceiling light. Is there a chimney cap that I can buy that will eliminate the problem?
  • 455 Answers
Hello,Yes there is a cap for every size chimney BUT that (while always being a great idea) will only prevent a WASHDOWN & keep pests and leaves out.The celing light conserns me that the roof flashing is leaking near the chimney during wind driven rain.Try a cap it can't hurt & I hope it works.
Posted on Oct 01, 2010
Water dripping onto passenger side floor from the inside passenger assist handle.
Does your car have a sun (or moon) roof? A leak in a sunroof will sometimes follow the roof over to the door post and down to the floor were the water will accumulate. This can be hard to find sometimes but having one person spraying water on the roof while a second one checks the inside of the vehicle you may be able to pinpoint the leak.
Hope this helps.
Bob
Jan 05, 2015 | 2003 Chrysler Town & Country
I have a 2009 Kai magentis, I need to replace wind shield, does the wind shield have a censor in it or can I place with ordinary windshield
ask supplier of winshield
The most common modern rain sensors are based on the principle of total internal reflection: an infrared light is beamed at a 45-degree angle into the windshield from the interior - if the glass is wet, less light makes it back to the sensor, and the wipers turn on.
TeleGlass Auto Glass The Easy Way Windshield Rain Sensors
Do Have Rain Sensor Gold Coast Auto Glass
Oct 13, 2014 | Arkon New Cmp114 Camera Video Recorder...
2001 chevy blazer wont start when raining. will start after a lot of cranking
Check your secondary ignition system, cap, rotor, wires. I suspect either the cap has a lot of condensation in it and is not allowing spark to the plugs or the plug wires are getting wet and leaking spark before it can get to the plugs. Should be pretty easy to check after a long hard rain or if it has been some time since you last tuneup these items along with spark plugs are most likely due for replacement anyways.
Oct 05, 2014 | Cars & Trucks
How to fix water leak for Ford e350 Econoline - 2007
pour liquid glass into your radiator, its hard to find but effective.
Jan 12, 2013 | Cars & Trucks
Water leak after hard rain, driver side, toyota corolla 2006
Check the door rubber seal for flat spots or maybe something stuck to it causing water to get past it.
Mar 19, 2017 | 2006 Toyota Corolla
When it get's really windy our pilot light get's blown out, we have a mobile home and want to know if the chimney should be raised
That's certainly a possibility, and there are caps/baffles you can add to the top that may divert wind as well.
But are you certain it's wind coming down the pipe? Make sure you don't have any other drafts that are making it into the unit at another location. If it's really windy and you cover the top does the flame still flicker at all? You might want to check that before you put in time and expense on raising the height and/or adding a rain/wind difuser on top... just to make sure. I lived in a mobile home a time or two, and they're notorious for those little gaps and leaks.
8^)
Jan 03, 2011 | Heating & Cooling
Our new bathroom fan is not clearing the room the ceiling is wet and the paint peeling the fan is model #FV-LP003
I use to be a chimney sweep. One of my jobs was to clean vents for dryers and bath vents. What could be your problem is that you have a bird nest in the vent system. It sounds to me that you have a vent on the roof for the fan. A bird could have damaged the cap to gain entrance and built a nest. With the cap gone, rain can come in. With the nest, it will not vent out the room. You could call your local chimney sweep company and they will clean it for you. Or if you are capable, Lowe's or Home Depot sell dryer vent cleaning rods. They are sturdy but flexible rods with a 4" brush on the end. Two other handy tools will be a high power shop vac to **** out anything from inside the vent, and a high power blower that has vacuum capability to use out side the house. Cafe full though, if it pulls out a nest, it will shoot it out with great force.
Jan 23, 2010 | Panasonic WhisperFit-Lite Low Profile...
The rain is the culprit. It studders, misses, dies. Won't start.
Check the distributor cap and rotor. A usual culprit in wet weather. The CHECK ENGINE light is most likely a side effect. Have codes checked to be sure. Hope this helps
May 05, 2009 | 1995 Chevrolet Astro
Water and debris in flue liner of Jotul Stove
You should have a swept T connector at the base, with the sweep going from the stove upwards, but the other end of the T going into a removable cap - or very short length of pipe. If you only have a standard bend - replace it with the T.
This is actually normal for wood burners. In an unlined chimney, the lighter "tar" fractions from the wood would soak into the brickwork, and show through the wall in a few years. In a lined system - they have to go somewhere, and usually condense inside the flue - running back down to the base.
The "chinese hat" style cap is actually very good for everything except sideways hail.
Sorry - but it's the nature of the fuel. It is possible to use a clay based absorbent at the base - Cat litter is actually fine.
Jan 03, 2009 | Kitchen Ranges
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
