Question about Dell 2335dn Multifunction Laser Printer
I have a dell 2335dn and I cant receive fax because the line always is busy. Help me!!
I can't send or receive faxes.
You have connected the phone line, right? Checked the phone line with a phone and you get a dial tone?
Aug 31, 2016 | Canon Pixma MX410 All-In-One Printer
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
Why won't the fax work?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Skelton Business Equipment Houston Copiers
May 08, 2014 | Sharp MX2610N Printer
Dell 2335dn freezes
this problem is related to logic board and power supply unit you need to log the service call to your vender or directly to support of dell,
Jun 07, 2012 | Dell 2335dn Multifunction Laser Printer
I can't receive Fax on this printer a960 I can send but not receive
Here is the Manual for the printer
Product Support Dell US
You need to set up the printer as on page 49 to automatically print faxes.
Nov 07, 2011 | Dell A960 All-In-One InkJet Printer
The fax machine will not faxes, it prints out as busy.
make sure the cable is in the LINE socket not the TEL socket as this will stop connection..
Jul 20, 2010 | Brother IntelliFax-2820 Laser Fax
Fax noise from all in one interrupts phone calls
Setup all in one fax setting to more than one ring.
Apr 01, 2009 | Office Equipment & Supplies
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Vonage vs Brither 4100
Have you called your own fax line and just listened to the fax hand shake? might sound simple but I have called fax lines before and it just rang, or it was busy or static, if your not getting a clear fax hand shake, then it is the phone line, if there is no answer you may have turned your fax to manual receive mode, If you don't know how it should sound call a friends business fax line and listen to it. I have actually gone out to businesses that reported send or receive problems just to call the line and listen to a disconnect message, that would make it difficult to fax.
Jan 13, 2008 | Brother IntelliFax-4100e Fax
Dell 2335dn Multifunction Laser Printer Logo
930 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
