Question about Braun Flex Integral 5314 Electric Shaver
How do you open a Braun 5314 Shaver to replace batteries?
  • Braun Master
  • 1,625 Answers
You will find replacement battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Start by removing the foil and cutter. Then remove the swivel frame by removing the two tiny screws on each side of the inside of the swivel frame.
To open the shaver you will first need to remove the two round screw covers on the bottom. Then remove screws. You can then gently pry the two halves apart from the bottom
Posted on Sep 30, 2010
Testimonial: "Thanks a lot. The tip was super and my shaver is again working fine."
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 screws
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
My braun 5314 does not switch on
Most likely, the battery needs to be replaced. Compatible battery type can be found at shaveroutlet.com
Shaver Replacement Battery AA NiMH
Jul 04, 2015 | Braun Flex Integral 5314 Electric Shaver
Where in Australia can I buy a foil
You can purchase a new foil for Braun model 5314 at shaveroutlet.com and have it delivered to your mailbox in Australia. See link below to webpage
http://shaveroutlet.com/shaver-replacement-parts/braun-5000-6000-series-flex-integral-flex-xp-foil-p-350.html
May 06, 2011 | Braun Flex Integral 5314 Electric Shaver
Braun shaver 5314. The green light works when plugged in. Does not hold charge to work at all. What is the problem, can it be fixed or should I begin looking for a new shaver?
Battery is dead. You will find compatible battery type at shaveroutlet.com. See link below
Remove foil and cutter. To open the shaver, pry off the two screw covers on the bottom and then remove screws. Remove the swivel fram on top by removing the two tiny screws. You can then gently pry the two halves apart from the bottom. You will be able to access the battery pack once the case is seperated
Dec 28, 2010 | Braun Health & Beauty
I have a Braun Flex XP 5614. It´s some years now, and I have to charge almost every second day. I thought it would be smart to change the batteries, but how? I have removed the two screwes, but I...
You will find the correct batteries for model 5614 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
To open shaver, first remove the two round or oval screw covers on the bottom of the shaver. Then remove the screws underneath, The can then slide the outer case of the shaver down and off of the shaver inner body exposing the batteries
Nov 20, 2010 | Braun Flex XP 5614 Electric Shaver
Charging does not work and is immediately empty
I believe that you are stating that your model 4775 Braun shaver no longer holds a charge. To repair this you will need to replace the batteries. To replace the batteries, you will need to open the shaver up. First, remove the two round plastic screw covers on the bottom of the shaver then remove the screws that are underneath. The outer casing will then slide off the bottom of the shaver. You will then be able to access the batteries.
You will find batteries for model 4775 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nicd-2-batteries-p-454.html
Mar 01, 2010 | Braun 4775 Electric Shaver
Open the shaver:
3) Using a small torq driver remove the 4 scews
4) Open shaver
Oct 25, 2008 | Braun Syncro 7526 Electric Shaver
How to replace the battery in Braun Model #5314 shaver
remove shaver head (2 screws)
remove 2 screws at the bottom of unit.
with coin, turn plug socket.
now pull carefully cover.
you'll need a welder to replace the 1.2v nimh rechargeable battery.
May 03, 2008 | RIM BlackBerry Pearl 8100
Braun Flex Integral 5314 Electric Shaver Logo
1,572 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
