Question about Motorola Mobility RAZR V3
My Razr's screen
Goes blank when I'm running a application , it sometimes does it 5 min into a session sometimes it takes longer or it happens before the applications even running properly . I need help or my phone might not survive another week .. I don't want to pay a fortune to get it fixed ..
thanks in advance
    Brigadier General:
  • 7,752 Answers
What you should do is have the phone reflash this should correct the issue with the phone.
Posted on Jun 02, 2008
Toshiba a135 laptop screen goes blank during battery use. only way to recover is to put the laptop to sleep blinking orange, and then restart. This action keeps the screen on. Could this be a bios problem?...
You indicated that this ONLY happens when the battery is being used and does not happen if the power supply is being used. This indicates that battery may very well be the problem.
More clarification ok? Do the following for me:
  1. Go into the Control Panel, and then Power Options
  2. For POWER SCHEMES, select never for each one
  3. For HIBERNATION, turn off hibernation
Charge up the battery some and then go ahead and remove the power cable and operate the laptop by battery alone and tell me if it is still going blank and after how many seconds or minutes.
If it is NOT, then I want you to go back into the POWER SCHEMES, and for TURN OFF MONITOR, go ahead and select after 5 min. THEN do the following two things for me:
  1. Wait for 5 min and see if it will turn off the display after 5 min or not.(note that this is after 5min of inactivity)
  2. After testing that, use the laptop as u normally do and tell me if it is still shutting off and tell me how long before it does
Please note:
These are two different tasks. The first one is testing to see if the software is working as u told it to work. The other test is to see if the laptop will still shut off even if there is no inactivity.
Let me know the answers to these things... so we can take it further from there...
cah
Mar 16, 2010 | Toshiba Satellite A135-S2276 Notebook
Screen goes blank when opening
Sometimes this problem happens when the wire for the screen get detached from the phone, or if the screen itself has a problem. It is common for flip phones to have this problem. To fix this problem, you need to take it to a repair center and have them reattach the wire onto the main board, which should not be very expensive.
Feb 25, 2010 | Motorola Mobility RAZR V3
Screen is blank but system will run does it have a
Check the battery. sometimes the stat can get an electrical shock, take the stat off the wall take out the batteries, if applicable, and set the stat down and walk away for at least 5 minutes then put it back, it might reset.
Aug 15, 2009 | Honeywell Programmable Thermostat Heater
Blank screen after monitor sleep just blue flashing light
First of all you can change the Power Settings in Control Panel. You can configure as you need. I mean after how much wait it should go for sleep n all.
If it takes 5 min. to wakeup that means you have so many applications running that system cannot manage or RAM is small.
The final solution just remove the Display drivers and reinstall it.
After removing please restart the system once to proceed further
Aug 03, 2009 | HP Pavilion dv9000z Notebook
Motorola Razr V3m won't register applications
dear sir,
I am want to downlod usb driver motorola v3 by internet .emedintly solve this problem
Mar 27, 2009 | Motorola Mobility RAZR V3
IBM thinkpad t41 screen goes blank after being used for about 5 minutes. Could it be a motherboard issue?
If the machine keeps running it might be your inverter or your backlight for your lcd screen. Next time it happens take a flashlight and hold it at an angle near your screen. I f you can see an image it's your screen that's having the problem. If the laptop is shutting down after 5 mins it could be a heat issue. Make sure all the vents are clear and the fan is running. If all those things are working then it could be your motherboard.
Mar 26, 2009 | IBM ThinkPad i Series 1412i Notebook
Formatting a motorazr v3
reflash the mobile , take it to a mobile service shop and have them do that for you
Jun 06, 2008 | Motorola Mobility RAZR V3
Pc screen goes black green light stays on
Well since you seem to have tried a bunch of thing why nor go a bit more and replace your video card. Below is a link to your PC:
http://support.packardbell.com/uk/item/index.php?pn=P280110001&g=1400
Dec 21, 2007 | Computers & Internet
Screen goes blank
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Oct 14, 2007 | Timex Ironman Triathlon 51931 wristwatch
Motorola Mobility RAZR V3 Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
