Question about Eagle Cuda 242 Fishfinder
My Eagle 242 does not turn on. What pins on the connector on the unit require 12v?
I have a eagle fish easy 240 it won't power on
1.Check the online fuse on your unit and be sure it is still intact.
2.Look at the connector on the back of the unit and be sure there are no bent pins.
3. Check the battery voltage and verify it's reading 12 volts or more.
4. Check the voltage at the connector to be sure you are getting power to the unit.
5. If you've accomplished all of this and there is power to your unit and it still won't turn on then it's time to invest in a new unit.
Jul 03, 2015 | Eagle Boating
Eagle Tech Consus Power adapter requirements
IF you have the Eagle Consus T ET-CSTSIU2-BK you must mean one of these (pictured). Check the exact model number of the units in the videos compared to the one you have. 3.5" hard drives need 0V (ground, earth), +5V and +12V which may be on the pins in a multipin connector in some external adapters or less commonly provided internally a single from dc or even ac supply. Further, your supply connector may not have multipins but be a multi-concentric ring type with matching socket (similar to a stereo plug). I suggest you try (discussing the matter with) Eagle support http://www.eagletechusa.com/customer-support/ or as outside chance buying another psu of the correct type from Amazon Newegg (who have sold out of this product) or ebay for example.
Dec 15, 2014 | Eagle Consus T ET-CSTSIU2-BK Metal 3.5'...
Need pin outs for eagle cuda 168
Coda has flat D 6 pin with center pin grd for 4 wire vs old arrow 6 pin round black one. Flat on bottom, count cw 12345 pins w pin 6 center... 2 pin minus 12 v, 4 pin +12v. For other 4 wire like speed/temp... 1 blue, 3(top) white, 5 pin bot right yellow, 6 center ground for spd/temp. White for speed wheel, rest not known. I used 2wire cable and 4wire cable with 2ft pigtails and 3amp fuse in red wire. I used old radio stereo 2 and 4 pin male female connectors at end of pigtails.
Nov 06, 2012 | Eagle Cuda 242 Fishfinder
Looking for manual
Dear Geraldnappy,
Check this link for the manual you are looking for!
http://www.retrevo.com/support/Eagle-242-manual/id/517ag923/t/2/
With kind regards,
MisterN
Aug 08, 2011 | Eagle Cuda 242 Fishfinder
Has power to unit but will not turn on
Some new fish finders are like the new cell phones, you've got to press and hold the power button a few seconds. Try about 5 sec.
Sep 06, 2010 | Eagle Cuda 242 Fishfinder
Do I plug in BOTH the 20+4 ATX power connector AND the 8 pin 12V connector on a gigbyte MB (MA790GPT-UD3h)?
Hi
You only need to plug the 20+4 ATX power connector and how about the 8 pin 12V connector? Well that is use only for legacy type of motherboard that use to require it.
Hope it helps..
Thanks for reaching Fixya
Apr 03, 2010 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
When I turn on my Eagle Cuda 300, it goes straight to silulator mode. When I turn off the simulator, it won't display the bottom and the depth reads way deeper that actual. I've tried changing settings,...
Try this, hard reset-FYI-This will delete saved data
1. Turn unit OFF-Press and hold the UP arrown key
2. Press power, unit will enter production keyboard test mode
3. Release the buttons
4. Press PWR/CLEAR key 7 times. (SYSTEM INFO SCREEN)
5. Press MENU/DOWN and unit will shut off
Hope this helps
Jul 12, 2009 | Eagle Cuda 242 Fishfinder
Cuda stuck in demo mode
to reset to factory presets,with the unit off; press menu down button and down button at the same time while pressing the on button releasing all buttons when unit turns on.... that should do it for you.....
May 18, 2009 | Eagle Cuda 242 Fishfinder
Eagle Cuda 242 Fishfinder Logo
44 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
