Question about Xerox WorkCentre Pro 580 Plain Paper Laser Fax
Can this fax machine be program with a code for security purposes?
    Sergeant:
  • 168 Answers
No, in this Xerox machine this isn't possible; this and other details could find in the WorkCentre_Pro_580 UserGuide
I hope this help.
Posted on Sep 30, 2010
I need a access code to recieve a fax
you have a fax machine or you have a fax program on your computer?if you have a fax machine you dont need access code.
Nov 27, 2013 | Brother IntelliFAX 1570MC Plain Paper Fax
Need to set up machine was given as gift
There are two ways to use a fax machine in your home or office. You can either have a standalone fax machine, or you can use your computer for this purpose. Either way, setup is very simple. You don't even have to be a tech guru to do it. First, decide if you'd like to have a separate phone line for your faxes so they don't interrupt communications at the office. If so, have the phone company install the line before you get started with fax setup.
Setting Up a Traditional Machine
  • Step 1.Set your fax machine on a flat and even surface. Plug the power cord into the wall. Fill the paper tray and slide it into the front of the machine.
  • Step 2.Plug one end of a standard phone cable into the phone jack and the opposite end into the port on the fax machine. It's usually on the back or the side.
  • Step 3.Turn on the machine and pick up its telephonemag-glass_10x10.gif. If you don't hear a dial tone, check your phone cable to make sure it's secure. Then turn to the LCD screen and start programming your options. Since all machines are different, see the instructions in the owner's manual.
  • Aug 03, 2010 | Office Equipment & Supplies
    How do you access bypass tray?
    The bypass tray is refered to as the multi-purpose (MP) tray. It is located vertically on top at the back of the fax machine. The fax needs to be programmed (told what size of paper is loaded) by opening the One-Touch Speed Dialing panel, press the 'Data Registration' button, press 'Set' button, then using up or down arrows to select " 5.PRINTER SETTINGS ". Press 'Set' button, then press down arrow to display " 2.PAPER SIZE ". Press 'Set', use arrow s to select CASSETTE or MP TRAY. Use arrows to select appropriate size of paper loaded. Press 'Set'. Press 'Stop' button to return to standby mode. Reference pages 15-11 and 15-12 in LC 2050 Users Guide.
    Dec 17, 2009 | Canon LaserClass 2050 Plain Paper Fax
    Our Brother intellifax 2800 won't receive some faxes
    Not entirely positive but it looks like you need to enable "polling" on your machine. I think it's a way to ensure they don't send out personal medical info to a wrong number by mistake. If polling is enabled, they've already determined that your machine is expecting a call from theirs.
    To enable polling on your machine:
    1. Press Menu/Set 217
    2. Use Up/down arrow to turn on polling
    3. Enter the fax number you're polling
    4. Press Fax Start to dial that number
    5. Press Menu/Set
    I hope this works for you. All the best!
    Greg
    Jun 17, 2009 | Brother IntelliFAX 2800 Laser Fax
    Faxing with a long distance code
    after you dial the number you hit the pause button (usually 1-2 times) then dial additional numbers.
    basically everytime you need the machine to wait for something to happen you need to hit pause
    example: i have to dial five digit access code for my fax for LD calls it would be dialed on fax like this
    1-234-567-8901 pause pause 12345 start
    May 04, 2009 | Brother IntelliFAX 1170 Plain Paper...
    I need to know how to connect my fax to my computer.
    hi there,
    May i know what is your purpose connecting those unit?
    If you want your computer can dial up internet connection, just plug your phone line to computer modem port and other side plug to the phone port at your fax machine.
    If you want your computer can send fax, same with above tips. but you must install fax program at your computer, so you can directly send fax through your computer.
    br
    Aug 07, 2008 | Computers & Internet
    PB 1630 fax machine
    it sounds like a programming issue, the machine should be auto recieve mode to work properly. but please be more descriptive on make and model and when it gives you the code
    mikey
    Mar 13, 2008 | Office Equipment & Supplies
    Paper Feed Not Automatically Switching to Multi-Purpose Tray
    Sounds like the paper out sensor for the cassette is either broken or jammed. Pull out the cassette tip the machine on its back and you should see a black arm hanging down. This should be able to swing back and fourth freely. Unless it is missing or broken.
    Jun 08, 2007 | Canon LaserClass 2050 Plain Paper Fax
    Xerox WorkCentre Pro 580 Plain Paper Laser Fax Logo
    Top Xerox Office Equipment & Supplies Experts
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    CheckitRight
    CheckitRight
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
