Question about Sanyo Xacti VPC-S60 Digital Camera
It dropped on the floor and it's lens are bent so it wont come in or out but i can still turn the camera on but it says system error
  • 38 Answers
The problem is more complicated to resolve at home.Ask a friend skilled in electronics or go to service center (too expensive)
Posted on Sep 30, 2010
3 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Bent lens
From what you describe it doesn't sound good. But here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Mar 09, 2008
SOURCE: Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Posted on Apr 10, 2009
Hi This morning my canon sx200 is dropped when it was open and i found little bent in lens cover. I could able to take picture also at that instance. But when i tried to turn off, lens could not able to...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 22, 2011 | Canon PowerShot SX 200 IS Digital Camera
My fujifilm finepix f60fd dropped one night and i tried to fix the lens. But now it wont allow me to take any pictures and is saying '' zoom error''. it does allow me to veiw my pictures.
Does it turn on at all, can you see things through the viewfinder or back screen (LCD) ?
My guess is when it fell, the lens got pushed in or to one side and it is now dented or bent and its getting stuck or hung up.I know that with my little canon if my finger is even touching the lens when it is trying to turn on, the camera wont work and i get a "Lens ERROR" code. My guess it is a safety feature so you dont burn out the tiny motor in the les system. youd either need to send it out for repair or ues this as a perfect excuse to up grade to a newer camera. One more thing, when turning the cam on, can you pull the lens out physically?
Jul 08, 2011 | Cameras
Dropped Samsung S630 digital camera. Lens was extended and after hitting hardwood floor became bent. Is bent slightly and stuck in out position. Camera makes 3 loud beeps when powered on and immediately...
This exact thing happened to me. The 3 load beeps is the camera warning that the lens has not been collapsed. Unfortunately in these little cameras everything is so tightly fitted and assembled that your best bet is to either replace the entire lens assembly or the camera itself. A quick search on eBay turned up no results for replacements parts so unless you have warranty, you may need to replace the camera. :(
Feb 01, 2018 | Cameras
Casio Exilim EX-Z60 won't turn on
This happened to me too, fiddle with the lens as its obviously stuck. Don't be too rough but try to figure out if it is slightly bent.
You will only be able to this if the lens is sticking out a little, enough to get a grip.
Good luck
Apr 12, 2009 | Casio Exilim EX-S600 Digital Camera
Lens Error!
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
'zoom error' on olympus sp-560 uz
I had this problem and managed to fix it. The camera was dropped on a stone floor and the zoom error was present every time it was turned on. A ring or other piece of the lens was bent or damaged, in my non professional opinion. A profesional repair is my advice. However you may try my fix at YOUR OWN RISK.
Switch camera on, when zoom extends, but before it closes down due to zoom error, gently but firmly push lens back in. Drop batteries for camera to reset itself. Repeat, if necessary.
My camera now operates fully and when the lens extends it now no longer makes the slight grinding noise.
Good luck and remember at your own risk.
Jul 30, 2008 | Cameras
Lens problem
Dear Customer,
When you say the lens barrel is bent, do you mean that the camera won't turn on ?, or the lens barrel is just bent and it looks outlandish. However if it's not turning on follow these steps:
1) Try to gently re-position the barrel, and make it more stortionate.
2) try to recharge ( or get new batteries ), and see if the lens will withdraw.
Unfornately, when you drop a camera, many warranties are voided, and you have to pay to have it fixed, but i doubt it would be that much money to fix.
Please rate this solution.. Thank You..
Jul 11, 2008 | Casio Exilim EX-S500 Digital Camera
Bent lens
Mar 09, 2008 | Canon PowerShot A520 Digital Camera
Sanyo Xacti VPC-S60 Digital Camera Logo
112 people viewed this question
Top Sanyo Cameras Experts
Tony
teddyboy
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
