Question about Frigidaire GLTF2940ES Front Load Washer
Doesn't drain well and has a bad smell - Frigidaire GLTF2940ES Front Load Washer
  • Frigidaire Master
  • 43,501 Answers
Here is a tip about how to clean your washer
Howto have a Clean Washer
heatman101
Posted on Sep 30, 2010
My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
I appreciate your inquiry, friend!
If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Why does my Whirlpool H2low washing machine smell bad inside?
Are you sure it's your washer or is there an awful sewage gas smell coming up your drain where your washer hose drains in.. I had this happen and I had to instal a U trap in the line the washer drained into.
Sep 09, 2014 | Washing Machines
Washer doesn't drain and smells bad
Check your pump and or filter to see if it plugged with something.
Apr 21, 2013 | Fisher and Paykel GWL11 Top Load Washer
Washing doesn't smell fresh after cycles complete
Are you leaving the door open when it is not in use? If it is a front loader, you cannot leave the door closed when it is not being used, it will get moldy and smell bad. If this is what is happening, try doing a full hot wash with bleach. It may take a few times to get all of the smell out.
Oct 10, 2017 | Tricity Bendix AW1400W Front Load Washer
Terrible smell inside the dishwasher. Bad drain smell
Hi
The smell usually comes when the unit is unable to drain water completely, you can run your dishwasher at its hottest temperature setting with 2 cups of vinegar inside the unit. After this take off the lower front panel and clean the drain pump assembly completely, also clean the drain hose, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Dishwashers
I have a water leak coming from under the dash board on the passenger side. Not sure where it is coming from. Any suggestions?
If it smells like antifreeze it's your heater core. If it doesn't smell and you have been using your a/c then it's your condenser or maybe a blocked drain tube. If it's been raining a lot or if you noticed after going threw car wash could be door seals, or even a windshield seal.
Jul 29, 2011 | 2002 Chevrolet Impala
When washing iwe get a horrible smell like bad
Is this a newly installed machine?
That smell would normally be associated with drains, indicating that the outlet from the machine to the drain is not correctly fitted with a trap.
Mar 25, 2010 | Indesit W 123 Front Load Washer
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
Smell when drains
THE VENT IS BLOCKED ON THE HOUSE DRAIN MAKING THE SMELL SURGE OUT OF THE PIPE WHEN THE PUMP STARTS PUMPING THE WATER OUT, CLEAR THE DRAIN AND VENT, SOME HAVE TO BE DONE FROM THE ROOF OF THE HOUSE,,,
May 29, 2009 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
