I have just purchased a syncmaster 2032 monitor and there is a 4 inch block in the centre left which the picture comes and goes. different colour lines appear in this area. If I turn off and back onn it fixes. can you advise what the issue is please?
    Problem Solver:
  • 41 Answers
Make sure you don't have any other electronic devices too close to the monitor, especially speakers.
Posted on May 25, 2008
17'' samsung synchmaster 794MG model display but screen shrinks from all sides ,After few seconds display becomes very small just about in single inch size .
hit your MONITOR lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some monitors on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width,etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......monitor main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )..............
Apr 14, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
My syncmaster 591s monitor is showing only green colour
Your picture tube has a problem already, when it goes green. Maybe you can try resetting all the settings to default, when you do so and it doesn't get better then its time to change it.
Mar 14, 2011 | Samsung 793DF 17" CRT Monitor
My Samsung syncmaster 2220WM will not stay on. It
The picture board on your monitor has been malfunctioning for quite the period but you did not notice it, since the screen goes blank, it means the picture board of your monitor has developed fault and will need to be replaced.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
My Monitor, which had never been used but been in storage for about 1 year, has a 2 inch translucent vertical pink stripe down the left hand side. Rest of image is perfect. Any idea how to make this go...
Check the RGB settings from the monitor panel.... Plus try moving the neck of the monitor left and right a couple of times.... Sometimes, the picture tube displays illegitimate pictures with some twisted cables or so...
Jan 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
The picture frequently breaks down into blocks of colour. my monitor is connected to the digital output on my pc and it is 8 months old
The first thing to checkis that the plugs on each end of the monitor lead are firmly attached. Next check that your graphics card is firmly seated in its slot. Next try a new DVI cable. If none of these work you may have a broken monitor.
Oct 31, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Every 10 mins my monitor goes black and then the picture pops back up
Its the poblem of SCREENSAVER which gets activated every 10 minutes.
In Control Panel, go to Display Settings / Personalise - - - - -> In Screen Saver select NONE.
Your problem will be solved for sure.
Apr 24, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Color problem
1. if your monitor is old. due to aging it happens normally
2. Check monitor signal cable
3. Else the colour processing circuit is defective.
4. Check whether your monitor settings are set correct(default)
5. Contact monitor service centre for further rectification
Dec 22, 2007 | Samsung SyncMaster 551 15" CRT Monitor
SyncMaster 920n Monitor 1 1/2" greeen colour vertical bar
Samsung products does not require u to produce a bill during warranty, ur product info will be registered in the database of the customer care center. So you can go in and get ur claim with the warranty. And the about the green lines, it could be that something is wrong with your graphics adapter.
Oct 12, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Jan 09, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
