2002 Mercedes-Benz C-Class Logo
Posted on Sep 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you show me the picture of brake lining wear and explain what that is? For Mercedes C230 2002
Michael Contreras
Level 2:
  • Mercedes-Benz Expert 166 Answers
  • Posted on Oct 01, 2010
Michael Contreras
Level 2:
Answers
166
Questions
Helped
104934
Points
396
I can't show you a picture of brake lining wear but I can explain what it is. Brake lining wear is your brake pad wear. If the instrument cluster is showing "brake lining wear' ' visit workshop' it means your brake pads have worn down and are now at the brake pad wear sensor.
1helpful
What does "brake line wear" mean on my 2002 S430
time to replace your brake pads. Many high end vehicles now have sensors to tell you when your brake pad linings are getting worn out.
2003 mercedes e500 brake lining light in insterment cluster how do i reset it
If the brake wear light on you can't reset the light without replace brake pads and sensors inside the pads must replace both after replace it will off automatically
I have the brake lining wear indicator light on
inspect your brake pads.when was the last time you changed your brakes
I just had my brake pads lined and it shows brake line wear visit workshop.what to do?they are still brand new..
when replace the brake pads you have to replace the brake wear sensor with brake pads if you not fix the wear sensors it will make fault control unit missing signal from wear sensor it will switch on the message on your instrument display check brake wear sensors are they fixed right way or not,
My mercedes E320 write in the display that i shall visit workshop because of break lining wear, is it dangerous to drive the car now? and what is exactly break lining wear?
Your car has a sensor on the brake components which detects when there is low brake life. Assuming your brake system is functioning normally; there will be no initial safety hazard/danger. You should have a professional inspect brakes ASAP because if you wait too long there may be additional damage that could have been avoided with a more expedited inspection.
How long can I drive my E320 when the brake lining wear light comes ons
its wise to change your pads asap but if your car feels fine then i recommend checking the pads yourself to see how much you have left on them.
i say this for i have had cars come to me before with the wear light on and theres been like another 2000mile left on them
7helpful
Warning lights in dashboard
hi,you have to check your brake pad, brake pad wear indicator lamp is lighting on your cluster, send your car to your dealer for brake check up and ask manual,ty
2helpful
Break lining wear
that warning is telling you the brake pads are approaching replacement time. have them inpected and will probably need service. i dont think you will lose your brakes, but have checked asap
Brake warning lining wear
Yes the parking brake uses a small set of brake shoes that act on a drum built into the rear rotor. There is no wear sensors on the parking brakes. There are however wear sensors on the front and rear brake pads. If your brake pad warnig light is on I would have the service brake pads inspected. 82210425
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
