Question about GE Dishwashers
My glasses are real cloudy after washing. My silverware is white. I have tried all kinds of products to no avail. Is my dishwasher going out?
  • GE Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 30, 2010
Cloudy dishes
cloudy dishes, white generally means an overdose of salt in the dishwasher, try turning down the salt setting usually set to 4 from factory
Oct 24, 2012 | Bosch Dishwashers
We purchased this unit in 6/10. It leaves a film on my plastics and does not get my dishes clean (glasses, silverware). I use Cascade complete and jet dry. I don't know what is wrong. Please help.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 07, 2011 | KitchenAid KUDS30IVWH Builtin Dishwasher
White coating on glasses, silverware and door of dishwasher that is very difficult to remove (even with a stainless steel scrubber) Is there a product I should be running through the cycle (without...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
Jan 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
Hard build up of cloudy film on glasses and silverware ruined.
Can you try using vinegar on one of the silverware pieces for me and let me know if that helps? Sounds like it may be a hard water issue.
Sep 26, 2017 | Kenmore Dishwashers
White spots left on glasses and silverware
The white residue could be water spots from hard water. They are most notably left on clear plastic glasses, clear glasses, and silverware. If your silverware is authentic sterling silver you shouldn't be washing it in the dishwasher anyways as this ruins it.------
The best advice for the hard water is to use jet dry there should be a dispenser for this on your dishwasher. The other solution is to use those oxi clean tablets or the cascade 2 in 1 gel packs. normally,this is caused by hard water. try using a dying agent like jet dry, it will stop the white spots. good luck.--------
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 19, 2010 | Hoover 24 in. DT999 Free-Standing...
Have Whirlpool dishwasher #GU2300xtsqo. White
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 16, 2010 | Whirlpool GU2300XTS 24 in Builtin...
Cloudy Glasses
The problem is hard water and jet dry will not solve that. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Jun 01, 2009 | Dishwashers
Dishwashers Logo
313 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
