Does it support sata if it does how do i get it to work
    President:
  • 2,571 Answers
Does what support sata?
look on the board, does it have sata ports, they will be by the ide sockets.
Or google the motherboard model number and specs.
You will get your detailed specifications.
OR write make with the make and model
Posted on Sep 30, 2010
Can I take a working SATA ACER notebook HD and put it in an ACER with 44 pin IDE?
Just check whether your hard disk is in good condition., what is the health percentage., It has any bad sector or weak sector,. before changing.,..(because if u use convertor it should work)
use harddiskscential for performance of your hard disk
SATA to IDE adapters any good
http://www.hdsentinel.com/ SATA to IDE Adapter Drive Not Detected in BIOS
Jun 05, 2015 | Acer Computers & Internet
System not recognizing dvd writer. new build. 2nd one I took the first one back thinking it was defective. HP dvd1270i dvd writer
Could be the motherboard's SATA connection is bad or not activated in the BIOS. I assume you have tested the SATA cable and verified that the SATA power connector is working. You may need to verify in the computer's BIOS that the SATA settings are on and correct. Do you have another SATA drive that is known to work that you can test in the computer to verify the SATA connection is working? Also some motherboards have a jumper on the board to disable and enable the SATA connection on the board. Verify that if there is a jumper it is in the correct position.
Nov 10, 2009 | Cars & Trucks
Do all motherboards support sata dvd
SATA is a relatively new technology, it is only 5 or 6 years old depending on the MB manufacturer. If this MB doesn't have built-in SATA connectors you may purchase an off-board SATA connector from several web based or local computer stores. This assumes that you are using an OS that supports SATA. Windows 2K and newer should support it adequately.
Sep 17, 2009 | Foxconn NF4K8AB-RS (NF4K8ABPX6200TC)...
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Jul 17, 2009 | IBM eServer xSeries 206
Wd1600aasd doesn't get recognized on my a8v motherboard.. i know it's an sata I but ppl tell me SATA II works.. plus the guy at the tech store knew it was a SATA I Board.. can this work or i have to return...
some via chipsets require the drives be jumpered to 150mbps, sata 2 is 300mbps. should work otherwise sata 2 is backwards compatible. read the paper on the drives they should have a jumper.
Jul 13, 2009 | ASUS A8V-VM Motherboard
Connection of DVD writer having SATA cable
The blue ports on this motherboard are SATA ports.
This is a SATA cable:
Mar 30, 2009 | Intel Motherboard
Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
Dec 20, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
