Question about GE Refrigerators
Zisb480dmc monogram, replaced Fresh food damper(-17 in freezer, 48 in refer), did not solve. Replaced Main board and fresh food thermistors, worked 10 days, problem became 44 in fresh food -27 in freezer. replaced freezer thermistor- -27 in freezer 38 in fresh food section. Evaporator is clear( no frost), and I'm just about out of ideas. Last ditch effort is evaporator thermistor. Any thoughts?
  • Anonymous Mar 16, 2014
    Location of fresh food thermistor
  • GE Master
  • 2,341 Answers
There's a temp sensor on the evap coil part WR55X10025,i would change that out and when you changed the board if there's a wire in the second pin of the connector with ithink 9 pins on it you have to cut the wire that's in the second pin,if there's no wire in the first pin but one in the second pin then leave it alone,look at the paper that came with the board and it will tell you what connector it is,let me know what you find,the old sensor has like a black piece on it where the wires come out of it,the new one is all white but you should change the sensor when you change out the board
Posted on Sep 30, 2010
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
What else can I check - my fresh food side of fridge is still too warm, freezer fine.
GE refrigerators use a board to control cooling and defrost functions. The fresh food compartment also utilizes a motorized damper, and some models even have a fresh food fan. Air enters the fresh food compartment at the top left corner, and the return air is also in the left wall down near the crispers. Both paths must be clear.
Jul 21, 2014 | GE Refrigerators
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
Damper wont open
send the model number and also did you change the mother board in the back of the fridge,wr55x10942,check out this picture of the board,it tells you how to read out the damper,thermistors,defrost parts
http://www.flickr.com/photos/zenzoidman/4482598198/sizes/o/in/photostream/also check this out if you can't find your tech sheet down where the front kick panel is
http://fixitnow.com/wp/2010/01/17/ge-profile-pss25-refrigerator-freezing-everything-in-the-fresh-food-compartment-regardless-of-temperature-setting-and-the-water-dispenser-quit-working-too/
Jul 11, 2012 | GE Refrigerators
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
Is there a work around for installing a new Temp Control circuit board in a GE Refrigerator Model # PSS27NGMA WW. Orig bd has 3 connectors and new bd only has 2 connectors. I am attempting to replace...
I have a feeling that the temperature control board is not the problem. The fresh food compartment has two thermistors that relay information to motherboard through your control panel. If thermistor is bad or covered by an item it will continue to cool and freeze fresh food. Your air damper between freezer and fresh food compartment may also be wide open. Click Here=> Service Manual Tech Sheet Click Here=> Tech Sheet If you need additional assistance please let me know here or HERE, Thanks, Sea Breeze
Dec 21, 2010 | Refrigerators
GE Monogram ZISS420N - Freezer works fine - refrigerator side is also freezing with thermostat set on 45 - repairmen (if you want to call him that) on five seperate occasions replaced thermostat,...
We are GE Monogram factory authorized service & parts and this issue sounds like your control board to your fresh food has gone out. The control board controls all the parts on your GE Monogram. You can contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
for all your appliance service issue and to get your parts.
We hope this solves your issue and we look forward to working with you.
Nov 07, 2009 | Refrigerators
My GE Profile fridge side isn't staying cold, but the freezer is. There is no thick frost built up in back of the freezer side so I know it isn't the defrost heater. Could it be dirty coils underneath the...
There are a couple of things that can cause this. Thermistors, mainboard, fan and damper.
Start with the cheapest.
1. Check Thermistors - Pull J1 and check connector pins 1,2,3 and 4 to pin 5. They should beapproximately 15Kohms. In your case, the freezer thermistors (pin 3 and4 ) should be higher than the fresh food (pins 1 and 2).
2. Fan and Damper - Fresh food fan should be on and damper from freezer to fresh food should be open. If not, check that fans spin by hand and damper doesn't look damaged
3. At this point it is most likely the motherboard.
http://www.fixyourboard.com/techzone/refrigerators/ge_fridge_warm/warmflow.html
Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator is a GE Monogram ZISS480NRGSS S/N SH031008. The temperature in both the freezer and the fresh food sides increased and did not go down. A technician came in and changed a valve (I do not...
We need to have a look at the main control board part number WRO2X11838 Tell me if the compressor is running while no cooling or if stopped. Unplug refrigerator and see if the top of compressor is too hot to keep you hand on. My drawing show the control bord in the area of the compressor and inside a box. Let me know if it has burn marks on both sides. Thanks, Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
May 20, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
GLRS237ZA
sounds like the tempreture thermostat in the fresh food is not sensing the tempreture properly, or the damper assy. is not closing or stuck open. you need to replace the thermostat for the fresh food section or the damper. their is a control box kit available
by frigidaire part # 5303918283 that will solve your problem.it has the fresh food thermost,the frz thermostat the damper and the board all together it retails for 235.99 -299.99. seen it at sears for 179.99. ,price just recently went up on these kits we still have one left for 129.99 + tax. + shipping . shop around and search for the best price .you will need that part # to search for part. good luck contact us if you need to orer or have any aitional questions. thank you
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE : allbrandsappliancerepair.com
email ; customerservice@allbrandsappliancerepair.com
Jul 11, 2008 | Frigidaire GLRS237ZA Side by Side...
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
