Question about Saniflo & Saniplus& Macerator Pump
We have a saniflo compact the toilet will flush 3 out of 5 times and the motor sounds fine but the other times when flushed it will sound like it is trying to flush and then just turns off at the end of the cycle but nothing has happened other then the water filling the bowl more
    Scholar:
  • Saniflo Expert
  • 115 Answers
This could be a problem with the capacitor that has gone bad or something stuck on the blade or impeller and is not allowing the waste to be pumped out. Typically when the capacitor has seized up or there is a clog on the drain pipe, blade or impeller; the unit will just hum and not pump the waste out and eventually back up on the toilet and overflow.
Posted on Oct 11, 2010
Can the flush mechanism be moved to an external site
Well now, that depends on your ingenuity.
If you can exactly duplicate the action of the flush handle, of course you can move it anywhere you please.
I am at a railroad museum, and railroads could move track switch lever mechanisms several hundred feet away from the switch, it just takes imagination and precision.
Saniflo will not be able to help you, but an inventor might be delighted to do so.
God bless your efforts.
Dec 15, 2015 | Saniflo Home
Saniflo compact part flushes when being used
Of course you should , the MAKER should make it right
May 22, 2017 | Home
When we flush machine runs and waste goes properly but waterlevel goes high . during flush time the toiletbowl filled with water
Sounds like your external pipe may have a blockage tap the pipe to see if your hear a thud if it sounds clear check the toilet outflow pipe the same.. You may need to have your external pipes rodded.
Jan 08, 2013 | Saniflo SaniPlus-Round SaniPlus Macerator...
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
System not flushing and motor cut out.
Motor may have been jammed and notw burned out.
May 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Jan 28, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo & Saniplus& Macerator Pump  Logo
506 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
