Question about Sony KDE-37XS955 37 in. Plasma HDTV
My mother bought a 2004 Sony Wega 37" plasma TV. Model # KDE-37XS955 The previous owner had the TV mounted on the wall, and no longer had the stand for the TV to sit on a console. I have contacted Sony and they have the correct stand, but the price is $250. She could get a new TV for not much more that that. I have searched online for the stand for it(E-Bay e.g.), but have been unable to find it. Are there universal stands that would fit this old TV? Where would I find it? The holes in the back of the TV are exactly 19" apart. She doesn't want to spend a ton of money on a stand. Any help would be appreciated.
  • 12 Answers
SOURCE: My Sony KDE-37XS955 won't show
I would need more information ,count the exact number of flashes and any pause in between flashes this is a code for troubleshooting. The TV went into protection mode
Posted on Dec 23, 2008
rob52078
  • 40 Answers
SOURCE: Need a base stand for Sony KE37XS910 Plasma.
X-4042-206-3 is the part number.. only place i found it was at encompassparts.com.. your part is no longer available but this is the sub part..
Posted on Mar 15, 2009
OnlyOneN
  • 86 Answers
SOURCE: sony Bravia KDL-32s2000 down from wall mount and can't find stand
Yes, Sony Parts has them available:
800-488-7669
The stand is $107.59, and requires four screws to attach to the TV. They're $2.25. (quite the bargain!)
The model number of the stand is X21033652.
Please rate my answer if it solved your problem.
Posted on Apr 20, 2009
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
  • 668 Answers
SOURCE: Sony Bravia 40" LCD TV Stand
There is a slotted area on the bottom of the unit and the bracket on the stand slides over top of it. There should have been four screws that came with the packaging that fit in the four locations in the lower center of the cabinet back that secures the unit to the Stand.
I hope this helps,
Skyassoc
Posted on Aug 25, 2009
My Sony WEGA KDE50XBR950 began to display the following error message: Fan Problem - Shutting Down, and then automatically shut down after a minute or 2. Is this a standard message when the fan stops...
I had this same problem last wk. It is either the heat sensor or the fan problem. My was the heat sensor and I took it to a local TV shop and they replace it for $250. For such a good TV, it is worth the $250 to fix vs. trying to buy a new one of such quality for $1000, that may not even have such as good pictures.
I bought a new 60LG 1 month ago for $2200 and it is no where as goo as this old 720P Sony in picture quality.
One question, do you still have the original TV stand that come with this TV? If you are not using it, I would like to buy it from you. I mounted the TV originally, but now want to take it off the wall and use a TV stand in another room. Please email me at ib1kid@yahoo.com
Dec 31, 2010 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Sony Plasma TV making a sound that sounds like a fan running when TV is warmed up.
Plasmas can sometimes run hot so there are usually a fan or two in the back of them that turn on and help cool em down.
Oct 06, 2010 | Sony KDE-37XS955 37 in. Plasma HDTV
Sony 50" plasma no picture model pdm 5010
Did you get this issue fixed? If not and you are giving up on this TV, I would like to buy the original Table stand that came with this TV from you if you still have them. I currently mounted this TV but looking to move it to another bedroom but I lost the original TV stand. Please email me at ib1kid@yahoo.com.
Feb 18, 2010 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Kde37xs955 sony with sound but no pic
This tv uses two power supplies. Do you hear a high pitch squeal? If so replace the small G power supply. If not make sure fans turn freely and finally change the large power G board. Look for obvious hot spots and swollen caps before buying board as the small bd. is approximately 129.00 and the large even higher. Part numbers on stamp on each board.
Hope this helps: Sam Farrell
Oct 07, 2009 | Sony KDE-37XS955 37 in. Plasma HDTV
37" Sony Plasma won't remain on
Your mainboard is damaged, replace it and that will solve your issue.
Jun 05, 2009 | Sony KDE-37XS955 37 in. Plasma HDTV
My Sony KDE-37XS955 won't show a picture. The green "on" light flashes, then changes to a red flashing "standby" light. Any thoughts?
Dec 23, 2008 | Sony KDE-37XS955 37 in. Plasma HDTV
XBox 360 and Other Game Connections
How are you connecting the XBOX 360?
Component? HDMI?
Make sure all connections are plugged in snug.
If you use HDMI then audio should work without seperate cable.
For component make sure red and white cables are also plugged into right spot on back of TV.
Hope this helps!
Thanks.
Mar 24, 2008 | Sony KDE-37XS955 37 in. Plasma HDTV
61 Inch Sony Plasma KE-MR61 needs to be repaired
Ke series makes that an early plasma TV
that old will probably be throw away or requires the replacement of the whole printed circuit of the TV
or power source
if chinese built that circuity may no longer be available
any local mobile TV repairer can check that TV out for you
check out the internet for sony corporation south africa
for parts availability
Mar 30, 2017 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Sony KDE-37XS955 37 in. Plasma HDTV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
