Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
LF flashes only when I use the "sheets" function. The LF appears 2 minutes after starting the cycle.
    Brigadier General:
  • 8,619 Answers
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won't change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
My Bosch max classic is showing error E2
http://www.fixya.com/support/t3342120-error_code_e2_mean_bosch_maxx
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Aug 18, 2015 | Bosch Washing Machines
All the function lights and pause lights flash
follow the steps and fix it. USE the VOM . God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
MY WHIRLPOOL CABRIO WORKS FINE ON EVERY SETTING EXCEPT THE SHEETS/TOWELS SETTING. MACHINES RUNS FOR A FEW MINUTES, THEN CODES LF. I HAVE UNPLUGGED, CHECKED ALL PIPES, SREENS, DRAIN PIPES.
LF is a long fill code,taking too long for water to enter.
Is the cold water valve filter screen clean?
Is both Hot and Cold water turned on?
The LF can also be related to the pressure switches.
Jul 25, 2011 | Washing Machines
Letter LF appear where the time should read. The washer just beeps and does not finish the load
This is a long fill (LF) check the inlet hoses for the screens being clogged...if it takes longer than 10 minutes to fill ..it cuts off and shows LF ..check that either water valve is not turned off or almost turned off...also, alot of people just use cold...make sure the selector is set for cold/cold if using this cycle...another possible fault is the mixing valve is bad/or going bad..Either way consentrate on this and you'll find your solution
Bruce Denton
Nov 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool cabrio washer that displays LF when I try to start a wash load. The water comes into the tub but it doesn't fill. After some time, maybe 10 minutes, the washer stops and displays LF....
Aha the old LF : Captain we have a problem. What is it Spock? Computers cannot confirm water is filling, water level does not change. Spock you did pay the water bill this month? What could it be Spock? Captain the inlet screens appear to have contaminants. Suggest you jettison them. If that does not solve it see test #2b7fe528.jpg
May 15, 2010 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
What does error code E2 mean? I have a Bosch Maxx Classic.
Nov 03, 2009 | Bosch Washing Machines
40C cycle stopped with 12 mins on display - now nothing works
Press "end of cycle" & wait for 2 minutes then try the door, do not force the door........................ If problem persists go to your model above & click on your model number & look for solutions....should find something.
Jan 12, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
149 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
